A/C Knob problem button. I push it in but it dosent click and stay on...
Old Jan 15, 2012 | 07:17 PM
Touring's Avatar
A/C **** problem button. I push it in but it dosent click and stay on...
when i used to push it it would engage by clicking itself in the halfway position but now it dosent click anymore. if i hold it in i hear the a/c click on and i can see the bluw light but it dosent stay engaged. anyone???
Old Jan 15, 2012 | 07:49 PM
nff's Avatar
nff
i dont have that problem.. my ac is 2x60 aircon
Old Jan 16, 2012 | 06:20 AM
DerrickS's Avatar
His name is spot
There is typically a mechanism inside the switch/button housing that works like an ink pen clicker. Most likely the plastic "catch" has broken and you will need a new button. I've never replaced one of these though, so I have no advice. Maybe you could take some pictures when/if you do it so that others can see what it takes?
Luck!
Old Jan 16, 2012 | 06:25 AM
Touring's Avatar
so you think its the button itself and not the actual metal ****? ill take pics as soon as it gets lighter out.
Old Jan 16, 2012 | 06:24 PM
Banzai's Avatar
Happy Rotoring!
You have to remove the shift surround then the stereo surround (the flat center pannel) to get to the ventalation controlls and the AC / fan control switch in question. It's not that involved. The buttons are plastic and just pull off. The switch mechanism itself is behind the dash ***** and where the problem would be. If you can diagnois the problem you may be able to fix it but used switches are not hard to come by.
Old Jan 17, 2012 | 03:23 PM
Touring's Avatar
OK here is a question i should have asked initially. when you take your a/c **** off and you push it does it engage/click or does it pop back out?
Old Jan 17, 2012 | 08:31 PM
Banzai's Avatar
Happy Rotoring!
When you push on your center AC button, it stays depressed and the blue light comes on. The mechanism beneath the button is what is actually doing the fuctioning and should work the same regardless if the plastic button is in place or not. Thats just a cover.
Old Jan 18, 2012 | 05:31 AM
Touring's Avatar
cool thank you. i recently took all that off to wire in my stero system so im sure i broke/ moved something while i was in there
Old Jan 18, 2012 | 06:09 AM
Touring's Avatar
looks like im going to need this whole assembly. how i could have messed that up... i have no idea...
Old Jan 18, 2012 | 06:25 AM
DerrickS's Avatar
His name is spot
I must be a bit confused about what you were describing. I don't know about earlier interiors, but on my 84 the AC is a button that you push in, and it clicks in the "down" position, and the AC comes on (with luck). Click it again and the AC turns off. I thought that was what you were describing, but from the picture above... I guess not.
Old Jan 18, 2012 | 11:06 AM
Banzai's Avatar
Happy Rotoring!
The AC switch / fan speed control is the unit on the far right in your picture. It's held on by the thin jam nut. If anything is jacked, it's that one control unit and can be had seperately. The other controls pictured are for the vent routing (defroster, center vents or footwell) and the air temp.
Does that smallest brass stem on the AC switch not stay depressed when pushed? That is what has been described.
Old Jan 18, 2012 | 06:23 PM
Banzai's Avatar
Happy Rotoring!
I took a couple pictures of the plunger in question. It only has about 2mm (slightly over 1/16) of travel between normal and depressed positions. If if does not stay depressed by itself, something internal to the switch is worn or broke.
Attached Thumbnails A/C Knob problem button. I push it in but it dosent click and stay on...-dsc05304.jpg   A/C Knob problem button. I push it in but it dosent click and stay on...-dsc05306.jpg
Old Jan 19, 2012 | 12:14 PM
Touring's Avatar
That is exactly what it is. Where can I find the clicker by itself?
Old Jan 19, 2012 | 08:45 PM
Banzai's Avatar
Happy Rotoring!
An AC/fan controll switch can be had from fourm members here or on eBay. You need the center push button style as opposed to the earlier and more rare "always on" version. That one has no push button center. Jim Hull from rotary restorations should have some.
Old Jan 20, 2012 | 09:34 AM
Touring's Avatar
Found one on eBay just have to wait till I get paid....
Old Jan 20, 2012 | 02:36 PM
rwatson5651's Avatar
79 w 13B4port
If they want more than a few bucks its a rip off.
Old Jan 20, 2012 | 03:51 PM
Touring's Avatar
12$ for the whole thing pictured
Devon300zx
15
Sep 16, 2015 06:57 AM
Apoc3D
Sep 5, 2015 10:24 AM
