Power Steering Issues
Old Jan 11, 2012 | 01:24 PM
FD3S2005's Avatar
SideWayZ The Only Way
Unhappy Power Steering Issues
ok well not sure if this is normal, but i just changed my inner and outer tie rods. and making sure the boots were set and tightened properly. i had someone move the steering all the way left and right.. Then i notice fluid coming down and knew it was ps fluid.
Looking where its coming from and i open the hood and look, everytime the steering is moving from left to right, i can hear air escaping from the cap and pushes out fluid.
Is this normal for our cars to do when its not started? Im going to start it and see if it does it when the car is on
Old Jan 11, 2012 | 07:01 PM
FD3S2005's Avatar
i dont think it does it while the car is on, could the steering rack be going bad?, this is how the boot looked before i changed it on the driver side.
Old Jan 11, 2012 | 08:26 PM
FD3S2005's Avatar
either its going bad, or im low on fluid now, but when i checked it didnt seem that low, went to move it so brother can his car in the garage and only when i turn mostly right i hear this noise.
Old Jan 12, 2012 | 08:10 PM
FD3S2005's Avatar
powersteering issue was fixed, appeartly my max and min indicator was stained and thought it was still full, it was actually low. i ended up draining out the old fluid and replacing it, (nasty brown color)
LunchboxCritter
15
Jan 3, 2016 04:11 PM
LMBTG
Sep 2, 2015 07:01 PM
c0rpse
Aug 25, 2015 11:50 PM
