Single turbo with no coolant cooler?
Old Dec 31, 2011 | 05:00 AM
Would a single turbo which is only oil cooled and does not need any coolant lines hooked up result in the FD running cooler as the coolant is not being used to cool the turbo compared to the twins?
I am sorry if this has been asked before.
Thanks
Old Dec 31, 2011 | 10:52 AM
Jason's Avatar
The one
I doubt your going to notice much of a difference.
Old Dec 31, 2011 | 11:16 AM
^^Agreed.
If anything you'll need to make sure you have at least the R1/R2 twin oil coolers.
Also, the proper way to delete the oem turbo coolant feed/return nipples off the water pump housing is to have them removed and welded over. I've seen instances where a 'professional' shop just looped the two nipples with hose which was almost touching the turbo manifold. After less than 1000 miles the hose was already crispy and failure-prone.
Old Dec 31, 2011 | 03:54 PM
thewird's Avatar
The Precision turbo's are only oil cooled, even the ball bearing ones.
thewird
Old Dec 31, 2011 | 04:41 PM
ryan1's Avatar
My pte bb6765 is coolant cooled.
Old Dec 31, 2011 | 05:02 PM
thewird's Avatar
Should have mentioned the new billets are oil cooled only. (not that the billet has anything to do with it)
thewird
Old Dec 31, 2011 | 06:45 PM
RotaryEvolution's Avatar
Sharp Claws
Originally Posted by GoodfellaFD3S
^^Agreed.
in all honesty it is application specific, even with a coolant cooled turbo the same can happen.
Old Dec 31, 2011 | 08:42 PM
^^Right, but using heat sleeving goes a long way, along with routing lines away from the heat sources where possible. Plus 'loop lines' are needless points of failure and should be eliminated where possible IMO
Old Jan 1, 2012 | 11:57 AM
Sharp Claws
true, i usually try to tap and plug the lines but i also try not to do anything irreversible when possible so i have looped lines before. but common sense sais not to loop a line right next to a 1600F cherry glowing hot turbo snail. some people lack common sense though, i'm sure we have both seen plenty of chucklehead mistakes by "techs".
that said, it's easy to point fingers and i am quite sure i have done a few things that someone thought to themselves "what an idiot move". hindsight is 20/20 so i try not to condemn everyone for being human.
Jan 11, 2016 04:08 PM
Aug 21, 2015 08:35 PM
