How many drips per min. While checking the Omp lines?
Old Dec 24, 2011 | 08:18 AM
Touring's Avatar
Just checking
Old Dec 24, 2011 | 09:15 AM
rxtasy3's Avatar
check here:
https://docs.google.com/viewer?a=v&p...6y4QE&hl=en_US
then scroll the left side of page down and click on page 106.
Old Dec 24, 2011 | 12:15 PM
clykins's Avatar
According to my FSM, when the engine is warmed up, you should be getting 1.8 - 2.2 cc/6 minutes at 2,000 RPM. Not quite sure what that equals in drips per minute.
Old Dec 24, 2011 | 08:21 PM
Jeff20B's Avatar
Lapping = Fapping
I have an OMP plumbed into the air horn of an Edelbrock carb. The OMP is jacked open to the 9 or 10 o-clock position (there is no way to rig a rod and/or I'm not going to bother lol). At idle it drips alternating every 5 seconds I think. Higher RPM speeds up the OMP shaft so I'd imagine it will drip slightly more often.
Old Dec 25, 2011 | 09:20 AM
85TIIDEVIL's Avatar
ALLROTOR
I've been beating the ***** off my 7 latey. Parked her up in the driveway last and oil was EvERYWHERE...! Poked around a bit and come to find out one of my lines from the OMP popped off.... hey, at least I know she's working. I have a 2nd gen 4 line pump Y'ed into two lines then to my Nikki. I secured the Y better and all is well again.
Old Dec 25, 2011 | 10:22 AM
85TIIDEVIL's Avatar
ALLROTOR
Haynes 79-85 manual = 2000K rpms @ 6minutes = 2.0 - 2.5cc
88 Mazda Workshop manual / Turbo = 2000K rpms @ 6minutes = 5.2 - 6.6cc
88 Mazda Workshop manual / Non-turbo = 2000K rpms @6minutes = 4.2 - 5.6cc
Old Dec 25, 2011 | 10:32 AM
Touring's Avatar
Mine is working what sucks is that the car was running perfect up until I added the 2 stroke into the gas just to be safe. NoW at a constant speed the car would jerk a little. I guess I should have left it alone but at least I know the omp works. Now to run all the gas out, after that I should be good. No more pre mixing for me.
Old Dec 25, 2011 | 11:49 AM
DarkDrakeX's Avatar
RX-7 NUT
lol how much did u put in?? and did u run a suitable premix oil? Good thing that it works tho.
Old Dec 25, 2011 | 12:20 PM
ray green's Avatar
Gone
As I recall from another one of Touring's posts he dumped in the whole 16 oz bottle.
On top of a correctly functioning OMP that could be enough oil in the gas to produce some staining over the tail pipe and a few hick ups once in awhile. Should straighten out when he uses up that gas and the engine will be well oiled.
FD7KiD
15
Feb 26, 2021 10:12 PM
Kyo
Apr 13, 2019 09:24 AM
BLK 93
Aug 19, 2015 03:47 AM
