White 1987 GXL Build {Lots of Pics}
Old Nov 28, 2011 | 10:31 AM
DCRotor's Avatar
Talking White 1987 GXL Build {Lots of Pics}
Welcome all to my little spot on the inter-web. Say hello to Becky…..she’s my white girl, LOL! (^_^) She is my second…2nd Gen Rx-7…. it’s a 1987 GXL. Bought her from some kid with pricings in February. From looking at it this kid did not know what he was doing with this thing, although he had three of them in his mom’s garage, including a turbo that from the looks of it was set up to drift. The car came with a 5-speed swap that wasn’t complete (-_-). The seller “said” the car was driven by a college girl and was never raced…… but as you can see the car came with a RB race header to glass pack to 4.5” fart can! (O_o)
Also the AC was removed and air pump was disconnected……never raced I highly doubt it.
The car had some problems that he couldn’t fix (hard start, 3800rpm hesitation, random surging, and electronics) First week added the grounding wires explained in Aaron Cake’s web site(http://www.aaroncake.net/RX-7/grounding.htm) and set the idle. It became a daily driver.
A couple visit to forum member Fong’s super garage sale in MD and I had a under tray, rear speaker covers, ash tray, Bomez dual exhaust (to pass emissions), s4 lip, radiator shroud.
Hid retrofits from forum member TurboIIrotary
Reconnected the air pump, new alternator belt, and some fuel cleaner….. She passes emission in DC on the first try!
Next got some stainless steel oil cooler lines.
Old Nov 28, 2011 | 10:33 AM
DCRotor's Avatar
Zankoku Performance coilovers which are 12/10 - 16 way adjustable…..Can you say Stiff hard ride!!!! Plus Prothane bushings, Suspension Techniques rear sway
Rear strut bar
New Optima yellow top ……Got rid of the sucky 205/40/17 ……. and got some 225/45/17’s
Next was a nice brake master cylinder brace from Zero Level Motorsports
Also the air filter broke
So I replaced the plastic adapter with a metal one and smaller filter.
Angry Bird Security!!!!
This is how she sits now awaiting new inner tie rods and the angle kit from mazdatrix.com.
I also have a new clutch kit from mazdatrix, new pilot bearing and seal, new stainless steel/hard clutch lines, new master and slave cylinder, rear trans seal, and throw out bearing for the 5 speed swap. Just need to get a lightweight flywheel and manual starter.
Thanks for looking.
I have a lot of more photos but this will do for now.
Old Nov 28, 2011 | 12:07 PM
Celestial-Fc's Avatar
Brap brap bang?
looking good. more low and new rims and ur set.
Old Nov 28, 2011 | 12:21 PM
magus2222's Avatar
On the fasttrack!
not a bad build so far. never heard of zokoku coilovers......i wouldent trust off brands like that
and you need some real wheels
other than that, keep it up
Lloyd
Old Nov 28, 2011 | 12:39 PM
DCRotor's Avatar
I wanted to buy new black with chrome lip bullet mustang GT 17x8 - 235/45/17s fronts and 17x8 - 255/45/17 rears but my auto transmission started to slip if I push the car. So the clutch kit and swap parts ate into my wheel budget. These will be my winter tires for now. As far as going lower, if you have ever driven on DC streets you'd know they are horrible.
Lloyd
Zankoku’s are popular with the supra guys for going low enough to put the frame on the ground. (O_O) I went in on a group buy with my supra friends. They are cool but the spring rates are crazy 12/10 and the wait for them to be made and shipped from overseas was horrible. If I were to do it again I would have just bought some Tein’s with a softer rate.
Im trying to do quality name brand parts, and these had good reputation on the forums.
Any suggestions on parts are appreciated.
I have Karack's adjustable rear toe bar coming in sometime this week as well.
Old Nov 28, 2011 | 12:55 PM
magus2222's Avatar
On the fasttrack!
oh, well, i stand corrected. and 12/10 is massively too stiff, my zeals are 8/6 with proper valving, and i got a damned good deal on them lol.
anyways, keep it up
Lloyd
Old Nov 28, 2011 | 01:00 PM
DCRotor's Avatar
Thanks... but we will see about these Zankoku's, they may be good for supras but the rx-7 is a different animal as we all know ;-). Right now its a daily driver withe some drifting on the weekend once the 5-speed goes in. By the way can I haz your seals Plezzzzzzzzz!
Old Nov 28, 2011 | 03:29 PM
DCRotor's Avatar
I mean seats*
Old Nov 28, 2011 | 03:35 PM
magus2222's Avatar
On the fasttrack!
what seats? my infini seats? np, 1750 shipped
Lloyd
Old Nov 28, 2011 | 03:58 PM
DCRotor's Avatar
Wait, are you saying it's not going to be a X-mas gift?
Old Nov 28, 2011 | 04:36 PM
dwb87's Avatar
This is my social media.
Considered putting the fan shroud back on?
Old Nov 28, 2011 | 06:37 PM
DCRotor's Avatar
When I bought the car it did not have one so I bought one from Fong. Temps went down to about 1/4 or 1/3 on the guage. haven put the under tray on yet...guess im just lazy
I also came home early today and look what was waiting for me!
Old Dec 5, 2011 | 01:48 PM
DCRotor's Avatar
Update:
This weekend a lot happened….. First one of my teams drift car has ate a carrier barring that cost more than getting a new aluminum ::In my Jeremy Clarkson Voice:: drive shaft. Since he is a broke B#$% I agreed to buy his Aluminum drive shaft if he does work for me. Only because I have more parts than time to put them on
Trans swap….. 5 speed and driveshaft
New Master and slaves from Autozone
New Maxdatrix angle kit, new inner tie rods new fuses,….etc.
My friends 1987 supra MKIII with A 1uz-fe V8 Swap…. I’m doing the wiring later, but right now is awaiting a drive shaft.
GET TO WORK B@#$^
Old Dec 5, 2011 | 01:50 PM
DCRotor's Avatar
Removing the old inner tie rods
Outer tie rod end was done!
Oh my god the angle!!!!! But this is without the tie rods
Installed mazdatrix rack spacers and bumpsteer
DCRotor's Avatar
After tightening the bolts down I found out the angle kit is coned at the bottom and I have about 5-8mm if space before its flush with the knuckle…. I will ask the drift nuts about this later.
Almost done!
New angle…. I do hit something but I think it’s the sway. I will make the sure after the alignment.
Just a reminder we had to grind down a pair of vice grips to tighten down the inner tie rods like in the tutorial in the archive section.
Although I had a lot more parts I need to put on I did not have a chance to do it. Like Karack’s Camber link, prothane bushings, repainting the side moldings, relocation of the license plates and maybe cutting the front bumper.
I guess it will have to wait for another weekend.
Old Dec 5, 2011 | 04:03 PM
R-X-R's Avatar
nice stuff.,.
Old Dec 5, 2011 | 04:29 PM
DCRotor's Avatar
Originally Posted by R-X-R
nice stuff.,.
Thanks man. I've seen your build thread and you have a nice car too.
So I took my car to the alignment shop and they couldn’t align it. Went to the Drift set-up thread and found out to get a 0 toe I have to cut some threads off the inner tie rod. I guess I'll be taking my cutter to the tie rods....
Also since I don’t like the way the outer rod fits on the knuckle I'll take my drill to it!
Old Dec 5, 2011 | 04:31 PM
stevensimon's Avatar
looks good. you are probably hitting the front strut bar.
most of the drift guys(including me) just ditch both sway bars. the spring rate on the coilovers is enough to make the sway bars not very effective anyway.
Old Dec 6, 2011 | 07:39 AM
DCRotor's Avatar
Thanks, made a U-turn this morning and got some metal on metal grid .... so I think your right. I'll ditch it tonight or tomorrow.... right now its raining so we will see.
Old Dec 12, 2011 | 08:34 AM
DCRotor's Avatar
Update:
I finally got a chance to install the Karack’s camber bar this weekend and it is a great product. I had no problems with install or fitment. Adjustability was as simple as jacking the car up and unlocking the bar (two nuts) then adjusting, and then locking the bar.
Can’t really tell from the photos but the new camber link is about 1 inch shorter than stock.
I also took off the front sway bar but didn’t get a chance to cut my inner tie rods down due to not having enough time. Sorry guys I have more parts than time I have to put them on so they are kinda just laying in a pile in the house.
Sway bar end link were shot anywas…
Old Dec 12, 2011 | 08:36 AM
DCRotor's Avatar
The wheels still rub the inner fender… I guess I’ll take a hammer to it.
While taking off the front strut bar one of my coilover studs broke off the coilover and now just spins in the hole….damn-it
I have a small problem though, when I have the car on and I’m just sitting still after about ten minutes small amounts of smoke come up from the hood. I thought it was my exhaust…. Re-sealed it. Then I thought it was the front sway bar getting hot and burning the under hood shielding. Took off the front sway, but smoke still comes.
Looked over the PD and didn’t see any fuel, but I have a banjo bolt for that.
Any thoughts?
DCRotor's Avatar
Side note: The aluminum drive shaft came for the V8 Supra!
Sheba doesn’t trust it…
Nozzz!!!
After driving the car this weekend removal of the front sway and strut bars has soften my ride a bit, and with the rear end being tight up and starting to premix the car seems to want to be driven faster!
Old Dec 12, 2011 | 01:14 PM
taka21's Avatar
get to work brandon this becky of yours still has a long way to go ... needs more low
Old Dec 12, 2011 | 01:52 PM
DCRotor's Avatar
Taka I'd knew you'd find your way here You know good and well I can"t go lower because of the exhaust. Besides should you be trying to make that damn supra work.... Been down for a min. Sir
Old Dec 12, 2011 | 02:16 PM
taka21's Avatar
lmao i drove it back to school today. the driveshaft works flawlessly btw and so to the tension brackets i made.
now back to becky, just ditch the crappy piping or let me cut and re weld it so it hangs higher
either way you still NEED MORE LOW
