2nd frount iron #3 tension bolt hole striped
Old Nov 13, 2011 | 12:00 PM
lcausey383's Avatar
my problem is i have used 2 frount irons with the same problem . the #3 tension bolt hole has pulled the threads out now this has happend after i chased all the threads in both housings , with no problems in any of the other holes . Its just number 3 hole tried useing a bolt out of another hole with the same problem . so now what do i do ?
Old Nov 13, 2011 | 12:07 PM
EPD's Avatar
EPD
install a healicoil
Old Nov 13, 2011 | 12:36 PM
RotaryEvolution's Avatar
Sharp Claws
or run one of the longer lower left tension bolts. the stock bolts only use up about 1/3 of the threads in the front iron.
Old Nov 13, 2011 | 01:58 PM
lcausey383's Avatar
using the left lower bolt
now that sounds like a great idea why did i not thank about that will try tomarow and let you know .. thanks
13
Jan 9, 2018 11:19 AM
Murilli
Midwest RX-7 Forum
Sep 3, 2015 09:10 AM
