Power FC PFC repair other than Apexi?
Old Nov 8, 2011 | 07:27 AM
timhill78's Avatar
I just got word form Apexi that they won't fix one of the two PFCs that I sent to them because it's been modified. It has the pins that go to nothing removed. Is there another place that repairs them?
Thanks!
Old Nov 19, 2011 | 11:20 PM
timhill78's Avatar
anyone?
Old Nov 19, 2011 | 11:52 PM
Brodie121's Avatar
Did they mention what the issue was?
I bought one that was sent off and they didn't want to fix it, opened it up, turns out a few traces on the board where severed. Soldered them up and where good to go.
An electronics repair shop would possibly be able to fix it if it's an obvious problem.
It all depends.
Old Nov 20, 2011 | 12:12 AM
arghx's Avatar
rotorhead
I know a guy who sent his off to somewhere in Australia or maybe NZ and it took a really long time. He had an SR20 Power FC in his 240sx.
Old Nov 20, 2011 | 06:24 AM
timhill78's Avatar
I have time. It's just sitting on a shelf now. Can you find out where he sent it?
I tried the local places and explained the problem but they wanted a schematic of it.
Old Nov 20, 2011 | 07:30 AM
R-R-Rx7's Avatar
Rotor or no motor
im surprised apexi told you no because pins were removed. every time i sent them a power fc everything worked fine (except the 3 month wait)
Old Nov 20, 2011 | 09:30 AM
arghx's Avatar
rotorhead
I just emailed the guy, maybe he will remember. It was two years ago.
Old Nov 20, 2011 | 09:10 PM
timhill78's Avatar
They said it's against policy to repair a modified unit.
Thanks for emailing him!
Old Nov 20, 2011 | 09:34 PM
thewird's Avatar
You could have just said the pins broke lol. Its not like its under warranty.
thewird
Old Nov 20, 2011 | 11:30 PM
arghx's Avatar
rotorhead
Just heard back... "It was in Australia and I don't recommend using them. They took nine months! When I called him prior to sending it he said it would take a week. I recommend sending it to Apex directly. If they don't do it I guess he has no other choice but to send it to Austria. The guy is Trent Whyte at Mercury Motorsport. trent at mercurymotorsport dot com dot au "
Old Nov 21, 2011 | 02:18 AM
Mr rx-7 tt's Avatar
rotary sensei
PM me.
Old Nov 21, 2011 | 10:08 AM
timhill78's Avatar
Thanks for getting the info. It sounds like a last resort. I'll wait a little and see if I can come up with something else.
Old Jan 26, 2012 | 09:25 AM
timhill78's Avatar
Update. I had the PFC repaired by Peter Florance at PFTuning.com. He did a great job. Good communication and the price was the same as Apexi. The turn around time was about a month but I did tell him to take his time on it as I wasn't in any hurry.
Old Jan 28, 2012 | 01:14 AM
arghx's Avatar
rotorhead
Good to hear.
Old Jan 28, 2012 | 02:10 AM
Mr rx-7 tt's Avatar
rotary sensei
I knew he'd be able to fix it. He repaired your Power FC without a schematic. He's also VERY honest and methodical. Peter is brilliant when it comes to electronics, nobody is better. Glad your PC is fixed.
Old Jan 28, 2012 | 02:41 AM
kclements's Avatar
I would be curious to hear what he found wrong with it. Did he ever tell you?
Old Apr 24, 2012 | 03:51 PM
Herblenny's Avatar
DGRR 2017 4/26-4/30, 2017
I need two PowerFC repaired. My wires got shorted at the Dragon by my tire and didn't know what happened til I was taking the wheels off to take the bumper off for a tow truck. I've contacted both Peter at PFtuning and also talked to someone at Apexi.
Old Apr 24, 2012 | 03:55 PM
Herblenny's Avatar
Just got an response from Peter @ PFTuning... He thinks he can fix it.. so I am planning to send it to him pending cost.
Old Apr 24, 2012 | 04:31 PM
RotaryEvolution's Avatar
Sharp Claws
i have a customer going through the same hoops with Apexi who got a PFC with the pins removed by SR motorsports. if you have them install a PFC tell them to NOT remove the pins from the ECU otherwise Apexi will not touch the unit if you ever need to have them repair it.
Old Apr 25, 2012 | 07:32 PM
cewrx7r1's Avatar
Eye In The Sky
Wink
I have been known to use a 5 pound hammer on offending equipment.
It returns the equipment back into the basic building blocks of the universe.
Old Apr 25, 2012 | 08:02 PM
R-R-Rx7's Avatar
Rotor or no motor
Old Apr 26, 2012 | 11:11 PM
TopGunn's Avatar
Im having a problem as well and would like to see if this has happened to anyone:
My commander as of two days ago decided to quit turning on fully(stuck on Apexi screen), so I hooked a Datalogit up to no avail either. The FCBOX lights up, but I'm getting no reading from the ECU. Opened the PowerFC up and nothing looked burned or f-ed up. Car runs as it did before the problem.
Anyone? Lol
Old Apr 27, 2012 | 08:47 AM
Herblenny's Avatar
Anyone? Lol
in your case, My guess is that connector is bad. That, I think most electronic shop can fix..
I talked to PFtuning and also Apexi and one of the PFC I can send to Apexi.. other one, I'm going to let PFtuning take a look. Since my case the wires were crossed so I'm going to find out which wires and send it over next week.
Old May 1, 2012 | 08:05 PM
indispeed's Avatar
guess what my problem is??? my pfc is in japan to get repaired, but they won't touch it because the pins were also removed by sr motorsports. I told them that there authorized dealer remove them.... the rep from apexi told me me going to try to see if they can replace the pins. who knows what that gonna cost!!! oh, btw japan has week long holiday this week...
Old May 1, 2012 | 08:57 PM
Herblenny's Avatar
keep me updated about pin replacement too.. I'm having the same issue
