Megasquirt magasquirt questions.
Old Nov 7, 2011 | 08:05 PM
sideways-FC's Avatar
LOPEY IDLE
I want to put a magasquirt ecu in my car and I read aaron cakes how to on installing it,and I have some questions.are all the wires needed for installation on the maga squirt harness for the fuel pump and to wire in the wide band and stuff like that,how can I use the stock tps if when the throtle body is a third of the way open its already all the way out,and the part about adding a 4 connducter sheilded cas pick up wire confusid me a little I geuss if all the wires needed are in the maga squirt harness I can figure it out in the wireing diagram.
Old Nov 8, 2011 | 08:57 AM
Aaron Cake's Avatar
Engine, Not Motor
Seriously, periods, punctuation and sentence structure. Makes a post a hell of a lot easier to read and means you get better answers.
As shown in my writeup, you'll need to add some of the wiring for the fuel pump. The Megasquirt harness from DIY only provides the fuel pump trigger wire. You'll need to run your own wires to the pump, provide your own relay, and wire it up.
You will need to wire in your own wideband with the appropriate relay and fuse. My writeup covers this. Only an oxygen sensor input wire is provided by the Megasquirt harness.
The 1/4 range TPS is a bit of a disadvantage, but will work fine for the Megasquirt. The TPS is mainly used for accel enrichment, flood clear, and to tell the ECU when the car is at idle (for BAC activation, among other things). It is easy to retrofit a full range TPS so I'd suggest taking that approach. Failing that, the stock TPS will do the job.
My writeup needs to be updated regarding the shielded CAS wires. The new harness from DIY includes a twisted pair wire in place of the old single shielded wire they used to use. So all you have to do is add another twisted pair shielded wire, basically following the instructions in my writeup. If you are using MS3X, then you will need to replace the unshielded cam input wire on that harness with a shielded twisted pair wire for the CAS. I've not updated for the MS3X yet because I don't have one to use for pictures and such. When I get to that point in my Cosmo, I'll be making those updates.
The new DIY harness includes all the wires you'll need except the CAS wire. And if you go MS3X, then all the wires necessary are on the MS3X harness minus the shielded CAS wire.
Old Nov 11, 2011 | 10:14 AM
LOPEY IDLE
Well do you know where I can find a full range tps that will work on my s4 na tb? Your write up also says to run the map sencor vac line to the ecu but in all the pictures I have seen of this ecu I havent seen a place to put a vac line,because i have seen on haltechs they have a vac nipple coming out of the body of the ecu for an on bord map sencor.
Old Nov 11, 2011 | 12:56 PM
muythaibxr's Avatar
MegaSquirt Mod
The vacuum line goes to a hole on the back of the ms where the MAP sensor is located.
Old Nov 12, 2011 | 10:04 AM
Aaron Cake's Avatar
Engine, Not Motor
The little round Ford TPSs that Haltech users generally upgrade to (see the Haltech forum) are probably the easiest to retrofit. It just requires making a bracket and grinding the nut on the throttle body shaft to fit the TPS.
Old Nov 12, 2011 | 11:53 AM
LOPEY IDLE
Im kind of going back and forth on if I want to get the magasquirt or a haltech it will probably depend on how much money I have at the time.
Old Nov 16, 2011 | 01:31 AM
paganizondadude's Avatar
7LAB
Im gunna chime in with semi proper grammar and punctuation.
I still am not understanding the relay board thing or what other wires besides the MS3x harness I will need. Does the harness have the triggers for the fan, pump, ect.
Also how is the electronic boost through the MS? Never really heard anyone using it...
Old Nov 16, 2011 | 09:01 PM
muythaibxr's Avatar
MegaSquirt Mod
The relay board is only necessary if you're not reusing the stock fuses and relays that came with your 7.
You should ask DIYAutoTune your question about their harness. They have good customer support via email.
I know of several people using the MS's boost control successfully, and I think a few of those are using it on rx7s.
Ken
Old Nov 17, 2011 | 05:48 PM
LOPEY IDLE
I know my grammer sucks but I get the point out there!
Coochas
44
Nov 5, 2019 11:08 PM
sccarally
South RX-7 Forum
Oct 8, 2015 05:27 PM
Xepez
2nd Generation Non-Technical and pictures
Sep 22, 2015 03:15 AM
