Drifting Discuss Drifting and drifting techniques here.
peripheral port?
Old Nov 7, 2011 | 03:03 AM
joshuaput's Avatar
Electric is the mood.
peripheral port?
I am wondering who has had a p port 13b in their drift car? I am thinking about p porting an s5 na 13b then putting a turbo on it too. has anyone had any good luck/knowledge/whatever with this?
Ive been looking around and there isnt much information on peripheral porting and engine. anybody have any good useful links?
Old Nov 7, 2011 | 03:38 AM
driftfcbuckey's Avatar
RX7-Factory
over kill son.
big turbo, decently sized street port - full bridge will get you 500.
REW keg
Cosmo Keg
s4/s5 TII keg
you're going to spend $2k on 2 housings?
Old Nov 7, 2011 | 03:57 AM
joshuaput's Avatar
I can do it myself. just want to mess with it. wonder if I use a t4 or something if the throttle response would be quick. I dont need 800 hp to drift. 300 with throttle response is good enough for now. I figure it would be pretty easy with a pport. im not going to just power. I think it would be fun messing with it.
also thinking of doing carbs. I wonder how much power a pported na with carbs would get me. and response would be there I think.
Old Nov 7, 2011 | 08:40 AM
I fc3SLIDE's Avatar
****** disgusting!!! do it
http://www.youtube.com/watch?v=U4Vog...C24050FFAA73AB
Old Dec 1, 2011 | 03:55 AM
Slobalt7's Avatar
Wrong wheel drive **D
The one in the vid sounds sick!!!
Old Dec 1, 2011 | 06:56 AM
Zenki FC3S's Avatar
\\TRASHTALK//
FAGGAT in the vid... i was gonna rock my downpipe out the sideskirt just like that! with dmax fenders and BN too..
Old Dec 1, 2011 | 03:16 PM
I fc3SLIDE's Avatar
its his wastegate dump big guy an this is his new 20b setup
http://www.youtube.com/watch?v=gwJTl...eature=related
Old Dec 1, 2011 | 06:36 PM
bewst12psi's Avatar
My car is green
that car makes my dick hard.
Old Dec 1, 2011 | 07:02 PM
Justen's Avatar
Easier/cheaper to get a stock-ported turbo motor to 300. You don't see many people with peri-ports. And for good reason.
Plenty of power and response... past 9k.
Old Dec 1, 2011 | 09:00 PM
MRJACK$ON's Avatar
In regards to P-PORT info there is/was?? a thread with lots of detail on how to make your own housings,its in one of the other sections,i cant remember.
If you only looking for 300 dont even bother with PPORTS. A drift car is allready somewhat a high maintinance affair,let alone a Pport motor.
Im not sure what your expirience is with this style of motor,but apex seals take a beating even on the some of the better final finished housings,this is just the nature of the beast,this is why they require frequent tear downs & inspection,Im speaking from a road race perspective/Drag is totally different.
But it does sound like an interesting deal,I do like the carbed idea ,purely for its simplicity.....
Old Dec 5, 2011 | 11:28 PM
MRJACK$ON's Avatar
Is there anymore detailed info /pics on the PPT above (fuel set up)specifically.
Also wanted to add PP requires carbon or ceramic apex seals,and if the tune is not up to par bye bye ceramics,hello paper weights....
Carbon seals now become a wear item,motor will loose compression over time,but usually when/if they $H!T the bed,they will disentergrate somewhat & not screw your irons & housings.Sometimes
Old Dec 17, 2011 | 02:06 AM
nvmarx's Avatar
i have a 13bpp in my drift fc that i have been trying to build for 2 years, money holding me back. my engine was s4 tII as 99% of fc's in new zealand came out turbo any way i sent my s5 crate motor to a shop up north he cross drilled the e-sharf lighted the NEW s5 n/a rotors from the USA highst comp rotors avalible evin betted than rx8 one. all new seals springs new steel unbreakable apex seals 20b start gears 51mm peripheral ports 12aturbo electronic dizzy 10lb fly wheel excedy 5puck clutch all balanced etc etc i havent chosen a carby yet but it was built for 300hp at the wheels 315hp if a went efi. if you want a turbo pp you will need masive injectors custom manifold etc. with the right n/a efi set up you will get 300hp here is a link for throtal body you can get if efi not for you hit racing beat up the have a juicy weber 51mm ida carb built for 13bpp's
http://www.racingbeat.com/manuals/16602%20Weber.pdf
http://www.injectionperfection.com.a...nt/view/22/70/
and my car build thread, well not realy just fue photo's
https://www.rx7club.com/build-threads-294/my-s4-build-nz-styles-974868/
if you want to know any more pm me
Old Dec 17, 2011 | 07:54 AM
bewst12psi's Avatar
My car is green
https://www.rx7club.com/showthread.php?t=974868
Sweet build man. You guys in NZ definitely do things a little different than we do in the states.
Old Dec 17, 2011 | 09:32 PM
nvmarx's Avatar
cheers man mine is abit diferant from the rest as most fc's are turbo my fc is well as far as i know the only street/track car with a pp in it the others are full on track cars.
in nz you realy see a un ported motor with the older cars every man and his dog has a bridge port 13b or 12a in there rx2 rx3 rx4 s1 rx7. s4,5,6,7,8 all are turbo very rear case you see one pop up that some one has gone with a n/a motor.
we just like our cars very very low and loud lol hence why i had a pp built
josef 91 vert
14
Sep 17, 2015 09:22 PM
