Help! I think I have a transmission problem
Old Oct 25, 2011 | 11:53 AM
FC3S Vert's Avatar
Question Help! I think I have a transmission problem
When I take it out of "P" into "R" or "D", I don't feel the transmission engage. When in "P", I can't roll or push it. In "R" or "D", I can. The car only pulls a little when I rev the motor to 5500rpms or higher. Help!
BTW there is plenty of tranny fluid in it too
Old Oct 25, 2011 | 12:07 PM
SpikeDerailed's Avatar
This sh*t burns oil!
Sounds like its slipping pretty badly. Is there "plenty of tranny fluid in it" or the proper amount? To much can be just as bad as not enough.
Old Oct 25, 2011 | 12:20 PM
raksj04's Avatar
did you check the fluid with the car running and in park or netural? The car will not more in park because there is a mechical parking pin, at least in most auto trans. I have checked the fluid in the trans in my blazer with the car off and the level look ok but the trans was slipping. When I was told it needed to be running in N or P the level was different. I don't like Auto trans they **** me off.
Old Oct 25, 2011 | 02:04 PM
FC3S Vert's Avatar
When I took the fill bolt out, not drain, trans fluid spilt out. This was when the car was off and warm. It was jacked up from the passenger side. I have a feeling it may be the torque converter.
Old Oct 25, 2011 | 02:27 PM
RotaryEvolution's Avatar
Sharp Claws
fill bolt?
i'm pretty sure even these shitty auto transmissions had an actual dipstick. i'm not sure what you were checking.
dipstick should be in the engine bay by the firewall..
also note the tabs at the top of the image browser, where i found the answer to this simple question for you.
Old Oct 25, 2011 | 02:52 PM
FC3S Vert's Avatar
I will check again for dipstick. I see the "o" for oil dipstick.
Old Oct 25, 2011 | 02:58 PM
Sharp Claws
an "O"?
there's no stamp on the oil dipstick unless you consider the finger loop an O...
if i remember correct it is a black rubber plunger just to the passenger side at the rear of the engine at the firewall. pretty standard location for transmission fillers actually.
Old Oct 25, 2011 | 11:52 PM
FC3S Vert's Avatar
I guess I do have a tranny dipstick. Its black and you turn it to click it out. The fluid is in the shaded area at the lower end of the stick. Is this the way it supposed to be?
Old Oct 26, 2011 | 12:47 AM
raksj04's Avatar
Did you check it with the car running in park??
Old Oct 26, 2011 | 08:17 AM
FC3S Vert's Avatar
No, I'm fixing the OMP right now Does the level go up and down when the engine is running in "P"? Does it go up and down when it's out of "P"? Sorry for the noob questions. I've never had an auto before.
Also when you put it in gear, is the shifter connected to a shaft or is it electronically controlled?
Old Oct 26, 2011 | 10:25 AM
vrracing's Avatar
Karack already provided you with a pointer to the answers to all your questions. The Factory Service Manual (FSM) is available online. The AT chapter is here. You'll find the Troubleshooting guide on page 11 and the fluid level check procedure on page 15. Both page references are the PDF pages not the printed page number.
You have 5 posts so you're new to the site. A couple of tips that I think you will find will greatly increase the value you can get from site are:
1) If you have a question always search first. In the banner bar at the top of the thread/forum you'll see an option to Search this Thread or Search this Forum. In your case I would have tried "slipping", "automatic slipping", "AT slipping", "AT fluid level" etc. It's unusual for a question to never have been asked before.
2) Next look in the FSM. Mazda spent a lot of money creating that tome and not only does it include the how to remove, rebuild and replace information but it tells you how things work and how to troubleshoot problems.
3) Only then post a question and provide as much info as you can. You can put a description of your car in your signature so it's always available and this is important because there are differences between verts and coupes, turbos and NAs, S4s and S5s, etc.
4) When people respond to your questions be sure to read the whole thing. As noted before Karack said that his pict showed you what you need to know.
Hope that helps and good luck with your project.
Old Oct 26, 2011 | 10:43 AM
raksj04's Avatar
well I know you should have it in N or P other wise you may get ran over. I have been told to check it with the car running many times. Not sure why. But the level was good on my blazer when it was off, but way to low when it was running.
Old Oct 26, 2011 | 11:12 AM
FC3S Vert's Avatar
Thank you vrracing. I needed that bitch slap lol. I'll check the fsm and hope I don't need a new tranny.
Old Oct 26, 2011 | 11:42 AM
raksj04's Avatar
If you do swap in a Manual
Old Oct 26, 2011 | 11:57 AM
Sharp Claws
most definitely, you won't get a ton of assistance with the auto transmissions here as they are actually quite rare and had to be ordered as a factory option. i have only worked on 2, yes that is TWO automatic FCs in 10 years of rotary specialized work. they simply aren't worth fixing the auto in.
yes you do have to have the engine running and in park, the car should also be fully warmed up and the fluid level should be at the top of the hashed area on the dipstick.
Old Oct 26, 2011 | 01:49 PM
FC3S Vert's Avatar
Originally Posted by karack
most definitely, you won't get a ton of assistance with the auto transmissions here as they are actually quite rare and had to be ordered as a factory option. I have only worked on 2, yes that is two automatic fcs in 10 years of rotary specialized work. They simply aren't worth fixing the auto in.
Yes you do have to have the engine running and in park, the car should also be fully warmed up and the fluid level should be at the top of the hashed area on the dipstick.
great! Thank you
Old Oct 27, 2011 | 10:43 AM
vrracing's Avatar
Ha! I was trying to be polite and instructive! As you read the forums you'll see some "search first" responses that go way beyond a "bitch slap"!!!
The site is very valuable and as long as it is obvious you have done your due diligence people tend to be very helpful. Always keep in mind no one is being paid to answer your questions.
The auto tranny is a performance sucking black hole. A manual (either the NA or turbo variant) swap makes all the difference in the world. You can check the 2nd Gen archives (and search! ) for writeups on the process as well as this write-up to get a sense if you want to take a shot at it.
Old Oct 27, 2011 | 11:05 AM
raksj04's Avatar
I would sell you the trans I have in my moms garge with drive shaft for cheap. but it is in Wisconsin and I am not. shipping would be a lot to MA. I have the whole S4 N/A manual driveline in fact, somewhere.
Old Oct 27, 2011 | 04:42 PM
FC3S Vert's Avatar
I've read that I have to custom make a crossmember to fit the manual tranny onto my auto frame. I wonder if I just buy the manual rear crossmember if it'll work and bolt up just fine
Old Oct 27, 2011 | 05:27 PM
vrracing's Avatar
SEARCH! Slap! Slap! Slap!
It's been a while but IIRC the vert doesnt have the manual tranny mounting holes so you have to fab up a bracket. We based our's off of this writeup in the 2nd gen archive and it's worked fine for the last 5 years. We initially just put in the manual tranny with the NA engine (really woke it up) while we built the Turbo.
Old Oct 27, 2011 | 07:20 PM
Sharp Claws
all the autos have the mounting point about 4" further back than the manuals so no, you can't make it work without an adapter.
Old Nov 16, 2011 | 12:10 PM
FC3S Vert's Avatar
Update: Car was just low on transmission fluid. MOderators lock this up please
Enzo1944
Sep 6, 2015 08:57 AM
