Megasquirt MS2 no spark
Old Oct 22, 2011 | 06:40 PM
iiluisii's Avatar
MS2 no spark
i currently have my board set up for th rx8 trigger wheel like this link
http://www.msextra.com/doc/ms2extra/...a_36-2-2-2.htm
but not getting any spark. would a modded CAS work with my board the way it is or will i have to change the jumpers. also how will i set the CAS tooth when i stabb it?? thanks
Old Oct 24, 2011 | 12:21 AM
iiluisii's Avatar
Got it running. It was the shielded wire ground. It running but my timing is off. Does any body here know on what tooth do setup the vr sensor on the rx8 wheel
Old Oct 24, 2011 | 07:16 PM
iiluisii's Avatar
I got the timing fix it was a tooth off I will post all the setting and how I did it later for people that want to run the 32-2-2-2 rx8
Prediict
32
Nov 18, 2015 08:41 AM
Aramir
Oct 18, 2015 02:39 AM
