Naturally Aspirated Performance Forum Discussion of naturally-aspirated rotary performance. No Power Adders, only pure rotary power! From the "12A" to the "RENESIS" and beyond.
12a first gen to carbed 13b.
Old Oct 19, 2011 | 02:23 AM
fupersudge's Avatar
Having issues hunting down information on all the parts I will be needing to do this swap. I will be using a s4 6port 13b but I am not entirely sure what and all is needed for the swap besides the engine and carb setup. I have searched and everything I have found seems to be people going to EFI.
Anyone know what I need for this?
Old Oct 19, 2011 | 03:30 AM
REPU_74's Avatar
Parts u will need:
Gsl se oil pan & front cover if u plan on keeping ur stock omp lines,& 1 of 2 things either slot ur engine bracket or swap out ur crossmember w a gsl se crossmember since the 13b is bigger.
Old Oct 19, 2011 | 12:49 PM
fupersudge's Avatar
Originally Posted by REPU_74
Parts u will need:
Wow is that really it?
Old Oct 19, 2011 | 08:01 PM
Sgt.Stinkfist's Avatar
premix, for f's sake
u will also need to use an oil pickup tube from a 1st gen, and if your gonna just run premix and eliminate the OMP any 1st gen front cover will do. i just got done swapping a S4 6 port in my FB, check my sig
Old Oct 20, 2011 | 01:22 AM
fupersudge's Avatar
So I could hunt down another 12a front cover and slap it on the 13b and use the dizzy and what not from the 12a?
Or am I going to have to use GSL-SE stuff still. I am trying to avoid EFI and go with weber 48ida since wiring is not really a strong point of mine lol.
Old Dec 15, 2011 | 09:03 PM
350swapblzr's Avatar
I have a DCOE 45 with racing beat manifold that bolts to the stock 6 port lower for sale. Its on my summer daily driver and works awesome.
Old Dec 15, 2011 | 09:06 PM
12a dizzy is the one to use
Old Dec 29, 2011 | 03:28 PM
WingleBeast's Avatar
some sort of oil cooling system to replace the beehive as well.
Old Dec 29, 2011 | 09:11 PM
SpikeDerailed's Avatar
This sh*t burns oil!
I think he's planning to use the stock fc external oil cooler, since it will bolt up to a fc engine.
heywier427
Sep 11, 2015 04:49 PM
