front suspention top shock mounting block.
Im a bit confused.... Where is the white mark at on the top shock mount?
According to the fsm there should be alittle white dot that faces the front inside corner of the mount, but the shock mounts i have don't have alittle white dot there.
I see that in the picture that they provide for you shows a natch on the outer part of the shock mounts.
Would someone please clear this up for me, thanks.
the white falls off, but there is a little raised nubbin. or you can just look at it. if you really look at it, its pretty clear the strut isn't centered in the mounting block
did you figure this out..looks like i am now running into a ver that someone spun all the mounts and the alignment shop cant find proper camber.
