No power above 3000 RPM's
Old Jul 17, 2002 | 11:31 AM
AdamAnt's Avatar
My 85 GS just started this a few weeks ago. She has a complete loss of power above 3000 and sputters kind a like she wants to go but can't.
Is my cat logged or maybe a jet in my carb or even a fuel filter?
All of the ignition checks out perfect, i looked down the carb and both jets seem to be working fine.
What about my secondaries, how can i test them?
How hard is it punch through my Cat?
Help please!!!!!!
Old Jul 17, 2002 | 12:05 PM
diabolical1's Avatar
i'd start with the gas filter, then work towards the carbie. i know the gas filter is a bigger pain in the ***, but i'm more afraid of carbies than i am lazy ...
Old Jul 17, 2002 | 12:44 PM
jeremy's Avatar
male stripper
filter isn't hard to change, just messy. i would start there then go to the cat.
Old Jul 17, 2002 | 01:27 PM
Well, im having about the same problem, in exception that i have no power above 1000 rpms. And i think im going to just send my car back to the junkyard where i got it from. This thing is really starting to **** me off.
Old Jul 17, 2002 | 10:25 PM
you serious???
what have you done to it so far?
Old Jul 17, 2002 | 10:45 PM
coldy13's Avatar
Yeah, shutup kid.
blitz, i'd check your cat if you already havnt, when I got my car it would barely start and only run at ~350 rpm, if i even touched the gas pedal it would die. Gutted the cat, runs great, no problems at all until last week when my muffler exploded Oh well, got an apexi n1 thats going to be on there tomorrow.
Old Jul 17, 2002 | 11:30 PM
I pulled the cat out a long time ago, along with the air pump and the rats nest. It ran fine until just recently. I tried to let it run with my exhaust off to see if somehow my presilencer got clogged, and still no go. Replaced my old fuel pump that died with a new holley tahts regulated to 5 psi, the plugs are dark, so im running rich. I took apart my carb and reset the floats, but it runs even worse that before....
Old Jul 18, 2002 | 02:03 AM
jeremy's Avatar
male stripper
set the pump at 4. thats where i'm running my fuel pressure and i'm good.
Old Jul 18, 2002 | 11:54 AM
i'll give it a try
Old Jul 18, 2002 | 12:52 PM
MyRxBad's Avatar
EliteHardcoreCanuckSquad
Your carb right?
Talk to the carb'd guys about checking the acelerator pump and the other valve that can be blocked off in the air cleaner (anti afterburn?)
Old Jul 18, 2002 | 11:54 PM
Alright, i set the pump to 4 psi, and it runs a little better. Can anyone give me a list of pumps or valves to check?
Old Jul 19, 2002 | 12:52 AM
jeremy's Avatar
male stripper
check the check valve in the return line and make sure its still functioning right. also make sure you can blow through to the tank.
Old Jul 20, 2002 | 07:14 PM
AdamAnt's Avatar
Fixed!
It was my cat, I unbolted it and took it for a drive and what a difference, it's not a motor boat any more. I cleaned the cat out using a crobar and the car drives a great, a bit louder but who cares.
Old Jul 20, 2002 | 09:30 PM
jeremy's Avatar
male stripper
haha, a bit louder.
Old Jul 20, 2002 | 10:24 PM
Pittdp's Avatar
I thought my pump was at 7 psi, it is a carter, and it is running just fine.
Queppa
Nov 18, 2024 03:47 AM
Kyo
Apr 13, 2019 09:24 AM
C. Ludwig
Jan 30, 2019 06:31 AM
Microtech
Aug 23, 2015 11:04 AM
