Tranny problems
Old Jul 17, 2002 | 04:53 AM
Juan's Avatar
Im a tall midget.
Tranny problems
My friend has an 85 GSL-SE 5spd that wont go into 3rd gear at high rpms (while racing at the track). It doesnt grind or anything. The weird part is: While shifting from 2nd to 3rd, only in high rpms, it feels like it goes into 3rd but it doesnt do anything. It's going between 3rd and 5th gear, like if it was a "blank" gear, kind of like a neutral but inbetween 3rd and 5th. Does anyone have clue why this is happening?? Thanks.
Old Jul 17, 2002 | 01:24 PM
jeremy's Avatar
male stripper
shove up harder? does he try 5th and get the same result?
Old Jul 17, 2002 | 01:32 PM
riffraff's Avatar
smog nazi destroyer
he may be hitting the gates between 3 and 5. possible his syncros are going also
Old Jul 18, 2002 | 05:10 AM
Juan's Avatar
Im a tall midget.
He says it only happens going to third. It feels like it goes into a gear thats between 3rd and 5th. Gears dont grind or make any noise when this happens. Its like being in neutral.
Heres a quick paint drawing I made. It shows the position of the shifter when this happens.
Old Jul 18, 2002 | 12:34 PM
jeremy's Avatar
male stripper
you got me. even if the synchro was shot there would be grinding. does 3rd work ever? maybe he sheared it. other then that, tell him to pull it towards the left to see if it will mate.
Old Jul 18, 2002 | 03:10 PM
Juan's Avatar
Im a tall midget.
3rd gear works fine when not redlined. Even if you shift fast without redlining 2nd it will go in fine. It only happens at high rpms. Hes tried moving it to the left before and nothing happens.
Old Jul 22, 2002 | 01:07 AM
Juan's Avatar
Im a tall midget.
Is the 12A tranny any different from a 13B (GSL-SE) tranny? Theres plenty of 12A's around here and he was wondering if they will fit his car.
Old Jul 22, 2002 | 02:54 AM
RotorMotorDriver's Avatar
Seven Is Coming
I think it will fit, but you may not want to do it. The 12A trannys are weaker (or so Ive been told). And just so youre not the only one with a problem like this...Lately, my car has decided that when I shift from 2nd to 3rd at high RPM's as stated earlier, my car REALLY REALLY does not like to go into 3rd. if I try and put it in gear, it just doesnt go, no grinding or anything, it just wont drop in. If I hold the cluth in and let the RPM's drop, it will fall in once they come down below 6.5 or so, but everynow and then, anything over that, it just wont go in.
~T.J.
Old Jul 22, 2002 | 03:01 AM
Keaponlaffen's Avatar
In ma truck, when you downshift from 3rd to second, it won't go at all directly into 2nd, instead, I have to shift into first (without letting the clutch out), then back down to second... don't ask, it just works, and doesn't cause any visible problems...
Jeff
Old Jul 22, 2002 | 05:01 AM
Seven Is Coming
My car is pretty tempermental about 2nd too...
~T.J.
Old Jul 22, 2002 | 02:00 PM
jeremy's Avatar
male stripper
Jeff
try double clutching. my synchro in my old camry was toasted and i had to double clutch it.
Old Jul 22, 2002 | 04:16 PM
hmmmm... might be a good idea.... maybe I'll try that once it's insured for good....
Jeff
The1Sun
Sep 18, 2015 07:13 PM
The1Sun
Sep 15, 2015 04:45 PM
