Oil Metering Pump, Dead!
Old Jul 16, 2002 | 07:30 PM
my omp just died. from what ive read premixing 2 stroke oil in the gas is a solution. my question is, how much do i put in each fill up? keep in mind the omp is dead so i should be putting more than the people that do this while the omp is functional, right?
thanks
Old Jul 16, 2002 | 09:28 PM
P'cola FD's Avatar
Hamado things my way!
Damn Brad, that blows. Nice to see that your car is running, though. I think it's somewhere around 12 oz per tank, but don't quote me on that. I use Marvel Mystery Oil on mine (with OMP), easily bought at Wall World. BTW what did you ever do about your turbos?
Old Jul 16, 2002 | 10:11 PM
thanks danny
well, i just got threw installing a lower mileage set of turbos today. and when i crunk it up it threw the OMP code. so i added 12oz of 2 cycle oil to a full tank of gas. now its stuck in the limp home mode. i also noticed a oil leak around the primary turbo and wastegate actuator area, ran out of daylight to tell exactly where its coming from. question now is how do i get out of limp home mode now that the OMP is bad?
Old Jul 16, 2002 | 10:29 PM
P'cola FD's Avatar
I think you have to put a resistor in the circuit, and maybe remove the pump. Then reset the ecu. The oil leak might not necissarily be coming from the turbos either.
Old Jul 17, 2002 | 01:44 AM
rynberg's Avatar
Ouch, I feel for you. I had my OMP replaced under warranty earlier this year.
I had to wait 2 weeks for the part to arrive from Japan - $1500-1600 just for the part. About $600 for labor. Thank god for the warranty on that one.
Sometimes people sell their used ones, if that risk is acceptable to you.
Old Jul 17, 2002 | 03:14 AM
93TTRX7's Avatar
**** i don't like the sound of that...are these a sure thing to die out like the Fuel pulsation dampner, or do they varry. And how can you tell if it dies?
Old Jul 17, 2002 | 05:04 AM
scratchjunkie's Avatar
sexy no jutsu
i have a used oil pump for you...email me if you are interested at wesleyargh@attbi.com
Old Jul 17, 2002 | 08:14 AM
JM1FD's Avatar
A resistor will not work for the OMP circuit. There's a variable resistor, not unlike the TPS in the pump which reports back to the ECU the position of the pump.....SOOO you have to build a little circuit which would look at the commands to the OMP, then mimic those commands back to the ECU via the feedback circuit.
Old Jul 17, 2002 | 09:15 AM
allrotor93's Avatar
just replace it with a used unit. not that much of a bitch to do
Old Jul 17, 2002 | 05:33 PM
ok good news, the OMP is not bad. bad news, the problem is the wires that run to the OMP stepper motor got caught in a pulley and broke. they broke off right at the connector, maybe a 1/2in left sticking out of the connector. is there away to reinstall the wires into the electrical connector? or do i need to find a connector with enough of the wires sticking out to splice? man ive had the worse luck with this car!
Old Jul 17, 2002 | 06:28 PM
JONSKI's Avatar
5yr member, joined 2001
How do you find out if your MOP or oil injectors are malfunctioning? A "check engine" light?
Old Jul 17, 2002 | 07:57 PM
JM1FD's Avatar
I dunno about the MOP connector, but the other connectors of the car pop open so you can pull the wires/terminals out. Examine the back (where the wires enter) of the connector carefully for a mechanism to open it up.
http://www.***-internet.com/fd3systems
Snoopy FD
Dec 8, 2015 01:45 PM
LunchboxSA22
37
Oct 26, 2015 10:53 AM
