Fabrication Post your questions and projects on Fabrication of Interior or Exterior or custom audio and electronics here.
Made some exhaust diffusers today [lots o pics]
Old Sep 5, 2011 | 12:55 PM
CrackHeadMel's Avatar
Learned alot | Alot to go
Had today off, wife had to work (sucker) and the child was gone for the day, so I had the shop to myself at work and finnaly made my exhaust diffusers.
Made them from some 2.5" od 304 bar ends. Ignore the nick's and dings, I didnt really plan ahead to make these so had to make them with whatever resharp tools i had in the shop. 30min with a sanding drum and the id's will be perfect
Manifold side of the sleeve is machined to accept my primary manifold tubing. The sleeves are going to be welded to my manifold flange and the tubing, i will use an exhaust gasket however it will be completely separated from actual exhaust flow, and just serve as a seal
All that is left is some relief machining on the housings and to port the housing's to match
anyway, on with some photo's
Side by side with a T2 sleeve i got some measurements from
cosmo housing compared to my new sleeve
again
and some obligatory action shots
-Jacob
Old Sep 8, 2011 | 12:26 PM
teddyrx2's Avatar
One Luv "Till The End"
nice,
Old Sep 9, 2011 | 06:57 PM
Level Zero Motorsports's Avatar
Registered User
Looks good.
Old Sep 9, 2011 | 07:33 PM
Thanks.
Im curious to see how well they are going to hold up. Hopefully they don't break apart and find there way though the turbine side of my turbo.
Old Sep 10, 2011 | 12:30 AM
Registered User
They'll be fine. 304 has a fairly high melting point and from a more simplistic point of view, if the stock ones hold up the ones you made should be more then fine.
Old Sep 10, 2011 | 12:57 AM
Jobro's Avatar
SAE Junkie
The factory material will almost certainly be the patented 'super alloy' inconel. I don't think they will last as long as the factory inserts under factory operating conditions, but then again I would expect these to be used with a 'loose' manifold, turbine housing and a very well flowing exhaust.
Old Sep 10, 2011 | 01:42 AM
Templeton's Avatar
is tempted
Finally!! You have no excuse not to start finishing your build
Old Sep 10, 2011 | 12:37 PM
you have my flywheel socket, guess ill have to drag *** for another year.
Old Sep 11, 2011 | 02:29 PM
Templeton's Avatar
is tempted
im done with it, ill bring it to ya work this week
Old Feb 19, 2012 | 11:35 PM
USMChris93FD's Avatar
looks great
Old Feb 29, 2012 | 02:41 PM
tru_az1an's Avatar
mr.niceguy
I'm jealous...
FD7KiD
15
Feb 26, 2021 10:12 PM
mazdaverx713b
48
Apr 21, 2016 06:45 AM
FD7KiD
Aug 17, 2015 11:50 PM
