ACT or centerforce clutch?
Old Jul 16, 2002 | 01:29 PM
Which clutch should I use? My stock one is going out and I don't want to replace it with an OEM one. My car only has DP and exhaust right now.
Old Jul 16, 2002 | 01:31 PM
black99's Avatar
Lurking..................
I don't like centerforce, I had one and it wore out pretty quick. I've heard good things about ACT but never had one. Also check out SPEC Star clutches. Good quality and a few bucks cheaper than ACT. I had a SPEC in my car and loved it and felt it was very high quality.
Silex's Avatar
I persoanlly have the ACT street clutch and it has held up to even my tough foot . IT is pretty stiff though so it takes some getting used to.
Old Jul 16, 2002 | 01:32 PM
ttpowerd's Avatar
HARRRRRRRRR
I have the ACT and it is a very nice clutch
Old Jul 16, 2002 | 01:49 PM
Silex's Avatar
Mo power to ACT! Iz da bomb y0z!
Old Jul 16, 2002 | 02:00 PM
RX7Elmo's Avatar
ACT is very good and can easily hold the power. If you want to be a bit aggressive, u can opt for the 6-puck disk. Act is also very attractively priced.
Old Jul 16, 2002 | 02:10 PM
SoCalLove's Avatar
Had ACT in my eclipse. I just put ACT in my FD. Thumbs up
Old Jul 16, 2002 | 03:12 PM
Rated R1's Avatar
Oji San
I have never heard anything bad about the ACT. I have heard several bad things about the centerforce. I went with the ACT a year ago and I love it.
Old Jul 16, 2002 | 03:19 PM
neevosh's Avatar
The Dude Abides
I've had no problems with my ACT clutch. Only complaint that I've heard is that it didn't feel like it grabbed hard enough between shifts, felt stock.
Old Jul 16, 2002 | 03:27 PM
95R2-89TII Ground Zero's Avatar
Banned
Go ACT. I don't mind the centerforce, but the act is off the hook...LOL
Old Jul 16, 2002 | 03:33 PM
chachidu's Avatar
Yo man, dont get a centerforce. I had it on my probe and as soon as I put in nitrous it wouldnt hold worth ****. it is the worst clutch ever...it wore out after a few months of tough driving....dont waste your money
Old Jul 16, 2002 | 03:35 PM
Manolis_D's Avatar
ACT clutches are sweet I just put a street / strip in my 1990 TII... Engagement is a little snappier than stock (you can modulate / slip it nicely), but it'll GRAB if you want it to
Old Jul 16, 2002 | 03:40 PM
ErnieT's Avatar
Living life 9 seconds at a time
I've had the Centerforce and it didn't hold for more than 4months. I now have the ACT 6puck w/ the extreme pressure plate. It will handle anything you throw it. I also have used the ACT street/strip clutch with the extreme pressure plate. That is probably your best bet.
Old Jul 16, 2002 | 03:42 PM
Blackbeast's Avatar
ACT all the way...
Timmy
Old Jul 16, 2002 | 04:23 PM
pomanferrari's Avatar
Haven't tried the ACT. Have had the CF for over 2 years. PFS installed it. Come to think of it, I wondered if it's truly a CF or a stocker that was swapped in place ala Monsen? It has a reddish paint so it must be the CF eh?
Old Jul 16, 2002 | 04:25 PM
black99's Avatar
Centerforce should be a orangish paint..
Old Jul 16, 2002 | 06:43 PM
From: Minnesota, now in FL and I dont think I'm goin back
If your planning on going single down the line should you just get a 6 puck clutch right away?
Mike
Oh here are my mods, single turbo in a few more months.
Old Jul 16, 2002 | 08:29 PM
rx7tt95's Avatar
Photo Diety
FWIW, I toased an ACT HD pressure plate with the OEM disk. I then switched to the Extreme ACT plate with an OEM disk. Holding up ok, but doesn't love the dragstrip. I do ok with it there.
I'd stay away from the 6-puck as it's a solid hub design which will generate more driveline shock, especially on the gearbox.
If I were you, I'd run the ACT extreme pressure plate with the Clutchmasters stage 3 or 4 clutch disk. Both are sprung hub carbon/kevlar and should be better than the organic OEM disk that ACT offers.
Michel
95RX7
Old Jul 16, 2002 | 09:15 PM
ErnieT's Avatar
Mike
No, you only need the 6puck if you are going to drag race all the time. You'll need the ACT street/strip with the extreme pressure plate. This will suit your needs and then some.
