Question about an amp
Old Jul 16, 2002 | 05:38 AM
Hey, I was wondering where I should run a power cable for an amp through. Did you run it through a pre-existing hole in the firewall, Drilled a new hole, or something else? I own an 89 gxl.
Thanx,
Bryan
Old Jul 16, 2002 | 05:58 AM
Audiofight's Avatar
I used a wire hanger, straightened out, and fished the 4 gauge wire through the firewall next to the steering column.
I also ran an 8 gauge wire through there.
Old Jul 16, 2002 | 10:48 AM
Icemark's Avatar
use the factory grommits on each side.
As a rule of thumb you want to avoid running the wire near anything that moves like the steering shaft or in back of the brake/clutch/gas pedals.
Old Jul 16, 2002 | 10:58 AM
N1XRR's Avatar
I cut a hole in the grommet where the factory wiring harness goes thru the firewall. Works great.(be careful no to cut any wires)
Michael
Old Jul 23, 2002 | 05:31 AM
bingoboy's Avatar
Lava Surfer
id like to add a question to this...i can see where the factory wires go through from the drivers side under the dash, but where to they come out? the only place i can see where they might be coming out is like a foot away on the other side. anyone got any pics they have and/or could take to help me with this?
Old Jul 23, 2002 | 06:18 AM
You might need to use a clothes hanger (metal one) straighten it out attach the end to the end of the wire , and fish it through the hole, or you could drill a new one like a lot of audio shops do anyway. Then you can use a good caulking around the hole to keep water from getting through.
Old Jul 23, 2002 | 03:44 PM
wpgrexx's Avatar
thers a pretty big hole already on the p side right below where the cruise control is, theres a big black grommet pop it out, drill a hole in it and voila
Old Jul 23, 2002 | 03:59 PM
KNONFS's Avatar
B O R I C U A
Michael
Same here!!
Old Jul 23, 2002 | 05:19 PM
Therx7ist's Avatar
Run it through the factory wiring harness grommet. I put 8 gauge through there easily.
Old Jul 23, 2002 | 09:08 PM
Scott 89t2's Avatar
SOLD THE RX-7!
huge hole where the speedo cable goes though. just got keep the wires away from the pedals.
Old Jul 27, 2002 | 06:04 AM
i ran mine thru grommett by the steering column and have had no problems. another wiring hint, run your rca cables and remote wire under neath all that cnter console ****. cant see a trace of a wire in mine.
_Tones_
May 25, 2021 05:37 AM
HalifaxFD
Canadian Forum
126
May 9, 2016 07:06 PM
