Installing Carter pump - tips for little nuts on top?
Old Aug 15, 2011 | 11:54 PM
Alex84GSL's Avatar
No pistons baby
I've secured the bracket for my Carter pump on to the frame rail and I'm trying to follow everything in this thread (https://www.rx7club.com/1st-gen-archive-71/fuel-how-install-carter-fuel-pump-holley-fpr-529605/).
Now to screw on the three tiny nuts holding the pump on to the bracket. I've been scraping my fingers and trying to get a wrench in there for an hour. Is there a trick to getting those screws on?
Old Aug 16, 2011 | 05:40 AM
Kentetsu's Avatar
Hm, if I remember correctly, I installed the pump onto the bracket, and then mounted the bracket onto the frame rail.
Old Aug 16, 2011 | 06:28 AM
ray green's Avatar
Gone
That's how I did it too, into the stock bracket and onto the rail in the same place as the stock pump, using the same mounting hardware as the stock pump. The carter pump is a little smaller in diameter so I added some kind of metal band around the carter pump so that the clamp on the bracket fit tightly.
Old Aug 16, 2011 | 06:38 AM
t_g_farrell's Avatar
Waffles - hmmm good
I don't know about everyone else but I used the bracket that came with the Carter
fuel pump and had to drill some holes in the frame as it goes up over the rear axle.
I then mounted the bracket using the self tapping bolts from the kit. Then I had
to mount the pump to the bracket using those little nuts on the top.
Watch out tightening down those nuts, the threaded posts they go on strips
easily. One of mine got a bit stripped last time I had it off. I double secured it
using some large zip ties just in case. Also, put a good 1/2 inch of medium denisty
rubber between the bracket and your frame rail. It will help deaden the vibration
and noise. Some folks use pieces of old flip flops or mouse pads.
Old Aug 16, 2011 | 07:01 PM
Alex84GSL's Avatar
No pistons baby
Kentetsu & Ray Green, I know you guys know your stuff, so you must know some real tricks to bolt on that bracket when the pump is hanging there in front of the screw holes in the bracket! I'm putting mine up like Kentetsu did in the photos but when the pump is hanging on the bracket it blocks access to screw anything through the bracket.
Ray Green, maybe you have a different kind of pump? I've got a Carter 4070 and there's no way to use the stock pump parts for my Carter.
Thanks for the replies, I'm going to crawl back under and keep looking and thinking...
EDIT: Kentetsu, looking at those pics again it seems like your pump isn't quite perfectly vertical. Is that ok? Then I could get it a little higher.
Old Aug 16, 2011 | 07:49 PM
ray green's Avatar
Gone
Here's some photos of the stock 12A cradle, if that helps, from an 84/85 GSL. It's mounted on four rubber grommets, to keep the vibrations down. The pump bolts down to it.
When I put the carter in I just adapted it to that cradle, adding a metal band to make it fit the stock tie down band. I had to adjust the plumbing a little, but not much.
Old Aug 17, 2011 | 12:08 AM
Alex84GSL's Avatar
No pistons baby
Thanks Ray Green, I know that area well, I've been crawling under it for a week! But I'm sure you must be talking about a stock-type replacement. The 4070 I have will definitely not fit on the stock bracket. Although I'm using the rubber grommets again to help deaden sound on my new mounted bracket.
Old Aug 17, 2011 | 06:24 AM
ray green's Avatar
Gone
Whoops, my error, I just went back and looked at Mark's tutorial, I can see that a Carter 4070 is not the same Carter pump I put in, which was a low pressure stock replacement with inlet and outlet on opposite ends and a bit smaller in diameter than the stock pump. It is a tight fit in that stock cradle, I can see why you're having to get creative.
Old Aug 17, 2011 | 07:42 AM
Waffles - hmmm good
As long as its near vertical your ok, it just can't lay down on its side or upside down.
I was able to get mine to be pretty close to vertical but I only used 2 bolts instead
of the 3 they supplied. The 3 bolts to hold that pump are overkill anyway. Using just
2 bolts you can get it pretty close to true vertical.
Old Aug 17, 2011 | 11:18 AM
Kentetsu's Avatar
Yep, I've been running the pump in that position since the article was written. Never an issue.
Th0m4s
Feb 26, 2019 02:04 AM
astrum
24
Nov 15, 2017 08:44 AM
gabescanlon
Interior / Exterior / Audio
Aug 11, 2015 05:59 PM
