Haltech New Haltech-er!.and need a Start up map.(tips?)
Old Aug 15, 2011 | 07:15 PM
misterstyx69's Avatar
Retired Moderator, RIP
Ok,I am trying to get the old Beast up and running before I grow old!(quick!!.I am there!)
I have the Platinum 1000 with a TII engine.Prewired harness and a FFE crank trigger.
750 pri/1000 sec.BNR stage 3 Turbo and 3 inch RB exhaust.
Wiring:can I use the old Fuel pump Fuse Slot for 12v Switched?
I am going to run the Fuse block(haltech) directly to Battery.
Thanks Guys,car has been down 2 months and I would like to drive it before SNOW!.Summer has been a Fiasco.
Old Aug 16, 2011 | 12:54 AM
C. Ludwig's Avatar
www.lms-efi.com
You have an email.
Use the switched input from the stock ECU connector as your switched source for the Haltech.
Old Aug 16, 2011 | 11:17 PM
I got the email.Thanks Chris.( you da man!)
Now,How can I open files to look at them?,(seriously,my Laptop doesn't open them,I know it's my Fault!)
..you say the Switch wire for the ECU: On what harness plug?.Color of wire would be fantastic!
Old Aug 17, 2011 | 12:40 AM
C. Ludwig's Avatar
www.lms-efi.com
You need the ECU Manager software to view the map files. It's on the disk that was included in your kit.
The stock ECU connectors in the passenger footwell. Not sure which wire color off the top of my head. Use a test light to see which wire has positive voltage in the run AND start position. That is your wire.
gxl90rx7
Haltech Forum
Sep 14, 2015 03:09 PM
rx7shirley
Sep 2, 2015 02:11 PM
ray green
1st Gen General Discussion
Sep 2, 2015 06:35 AM
