Air atomizing nozzle???
Old Aug 15, 2011 | 09:19 AM
hiroichi1515's Avatar
I have been looking for two weeks trying to buy a single air atomizing nozzle so I can build a water injection kit that does not require the use of a pump. Does anyone have a direct link or one for sale or do I have to bite the bullet and buy one from ispray and drill it out. I will only be running a max of 18 psi possibly. Thanks in advance for the help.
Old Aug 31, 2011 | 08:42 PM
Supernaut's Avatar
Check out howerton engineering for aquamist nozzles. I don't know if they would work in your application though.
Old Sep 1, 2011 | 11:35 AM
Thanks but I no longer need one. I just built a system using a pump and it came out pretty nicely.
Old Oct 20, 2011 | 10:09 PM
XLR8's Avatar
If your pump driven system doesn't work out, PM me. I have a part number for an adjustable atomizer that will work perfectly. Flows up to 900cc at 21psi. Building my own system as well.
I am thoroughly sold on the manual pre-turbo setup utilized by Rice Racing and Wannaspeed. I simply want to design my own kit.
Old Oct 21, 2011 | 08:36 PM
I would have loved to build a manual system but I could not find the necessary parts to build that kind myself or afford to pay over $300 for it from wannaspeed. I'm running close to 1 bar of boost and it seems to be working wonderfully. My needs were met, although the atomization is not as fine as the manual kit. Still I have no complaints or can't say which one is better. I only can say they both work and that's the main think anyone is looking for in my opinion. My setup is a high compression s4 6 port engine with a hyrbid turbo. Still going strong with plans of upping the boost even more.
Old Oct 21, 2011 | 11:30 PM
XLR8's Avatar
I hope your kit works out. For pre-turbo, maximum atomization is very important. Usually, the biggest fear associated is blade wear.
I also plan to incorporate the Aquamist DDS3 V10 failsafe and flow monitor system.
Old Oct 26, 2011 | 02:06 AM
Shaman's Avatar
I wish someone would make nozzles for them small enough to be used with a pump to further reduce particle size. I have tried contacting both sellers that I have found here without much information.
Old Apr 13, 2012 | 02:12 PM
full-cruise's Avatar
D.I.L.U.S.I.
pm'd you
Old May 7, 2012 | 06:43 PM
Erdin's Avatar
Water Injection Specialist
If anyone is interested in Mechanical kits, send me a PM I have them on the shelf.
Shainiac
Jul 17, 2019 02:20 PM
FlatVermin
22
Sep 27, 2015 05:42 AM
BLK 93
11
Sep 9, 2015 10:56 AM
