Who has the Highest RWHP 6Port Turbo?
Old Aug 14, 2011 | 10:10 PM
MANSU_V36's Avatar
I researched and couldn't find the answer to my question. but i found this
http://www.youtube.com/watch?v=PN_4X..._order&list=UL
http://www.youtube.com/watch?v=eF5EP...eature=related
Let me know if anyone is pushing more RWHP.
Old Aug 25, 2011 | 04:38 PM
Osirus9's Avatar
Jackstand Drifter
Aaron Cake?
Old Aug 26, 2011 | 02:45 PM
Thumpher86's Avatar
Rotor-aholic
Was he using na or turbo rotors in the video?
Old Aug 26, 2011 | 11:51 PM
coolmike711's Avatar
how much did he push? Didn't see any numbers
Old Aug 28, 2011 | 10:24 AM
Aaron Cake's Avatar
Engine, Not Motor
The description of the second video says:
"Couldnt finish tunning due to ignition breakup after 6000 rpm, but was able to get 447 at 22 pounds,"
There is something seriously wrong if a T70 13B is only making 447 RWHP at 22 PSI. Ignition breakup would certainly do it.
But to answer the question, the highest RWHP 6 port turbo (at true turbo-NA and not a "6 port TII") is probably me, at just a little North of 500HP. I'll save the exact number for when I get around to another dyno run. Or, it might be J-Rat. He had a fairly high HP 6 port turbo engine as well but I don't know the current status of that car.
Old Aug 28, 2011 | 04:39 PM
Frostycrowd's Avatar
I have always wondered what the most powerful 100 percent stock 6 port block was, no port, only mazda parts. I did 401 (dyno dynamics) at 16psi, I pushed it up to 20 at one point but never dynoed it. By my estimation it was making 450whp at least. (I since sold the turbo setup)
Old Aug 28, 2011 | 04:52 PM
bigdv519's Avatar
IFO Forced Induction Slo
Whats your highest dynoed so far?
Old Aug 29, 2011 | 03:41 PM
Aaron Cake's Avatar
Engine, Not Motor
I've only had the car on a dyno (DynoCom dyno) at 13PSI with a tune that still needed to be refined and it was just over 400 RWHP and just over 300 FT-LBs.
Old Aug 30, 2011 | 12:10 PM
Clubuser's Avatar
Very impressive!!! Would stain my under's w/them #s out of my TII.
@ what RPM, ps ?
Old Sep 1, 2011 | 07:17 PM
RotaryEvolution's Avatar
Sharp Claws
J-rat sold his car so now he's rotary-less and brings me shop towels in the meantime while he looks for a replacement.
i wasn't even aware he had ever built a high comp engine though unless that was his most recent one that Glenn built for him after the turbo popped the first.
Old Sep 2, 2011 | 09:21 AM
Aaron Cake's Avatar
Engine, Not Motor
@ what RPM, ps ?
I'd have to go back and look at previous dyno sheets. From memory it makes peak HP around 8500 RPM.
Maybe it was SonicRat? It was one of the rats, anyway.
Old Sep 2, 2011 | 04:52 PM
Sharp Claws
that was probably it, but i honestly dont know it could have been Jrat as not alot of specifics were told about his newer built engine.
Old Sep 7, 2011 | 05:59 PM
Cosmo_TT's Avatar
BRAAAAAP pssh BRAAAAAP
I said NO he cant have my car!!!!!!
Old Sep 8, 2011 | 01:44 PM
NI_Racing's Avatar
Racer
Aaron... 500 is very nice. We have an event coming up in Oct down here in Fl called rotar fest and if i can get the car ready i will be taking my completely stockport unopend 6port s4 to the dyno with a sport 1000 and precision 6765 turbo. The date is getting closer faster than i wanted it to, so i need to get to work. I was thinking 400whp would be achievable at 15psi on pump gas without worry but was assuming i would need water injection to get into the 20's on pump gas (93 octane)? If i ever get this thing together i guess i'll find out
btw i would love to get some ideas of the maps you were running if you would be so kind
Old Mar 15, 2012 | 09:01 PM
o0Quicksilver0o's Avatar
Wow, very nice.
Old Mar 24, 2012 | 11:24 PM
SonicRaT's Avatar
Super Raterhater
Thread from the past!
I had so many different setups over the years in my GTUs, the most power I pushed was around the 530 mark with a GT42R on a dyno down near green bay. I ditched that setup and went to a 35R, simply because the the places I ran/drove the car really didn't fit with that turbo setup. The car then sat for a long time after many of the parts were stolen, and I've only recently rejoined the FC 6port turbo bracket by rebuilding it as a sequential twin-turbo running on a megasquirt.
Old Mar 30, 2012 | 02:45 PM
rotaryB-2000's Avatar
Psalms 37**25
i have one buddy with 750 to the wheels with a alcohol semi-Pport full 1988 6port using the N326 high compresion rotors and another 6port with a 93 rotating asembly making 700 to the wheels on Gas
Old Apr 27, 2012 | 02:30 AM
HIrotary's Avatar
any videos or pictures?
Old Aug 3, 2016 | 01:15 PM
Hygoog's Avatar
Hi whats the max hp I can achieve with the stock s5 turbo on my s5 6 port? I would like 250-280whp if possible or should i just go with a bigger turbo? Thanks
Old Aug 5, 2016 | 09:20 PM
Jimmy2222's Avatar
Nice thread rez. At least look into BNR or hybrid options, I would not bother especially since you have a high compression engine. It could work, but I wouldn't roll those dice, especially if you have stock top mount//everything else...
Old Aug 6, 2016 | 08:50 PM
ColinShark's Avatar
RX-7 Old Timer
Yeah, you'd be lucky to hit 250whp. Regardless of engine, you'd be maxing out the compressor's airflow. You can only make so much power with that much air. Torque will spike in the low end, and trail off to redline, while the horsepower line will look flat.
That's actually how airflow-restricted race cars set up their engines, but when you have the option of changing parts, you'll want a bigger compressor.
Old Oct 15, 2017 | 07:39 AM
Hygoog's Avatar
It's been awhile. I decided to ditch the ht18 and go with a garrett airresearch T04B-35 that I got for dirt cheap and practically new. Picked up a cartech manifold too so hopefully I can keep my 5th/6th aux and stock manifold. This cartech turbo manifold is specifically designed to do that... except Ive never seen it installed on an S5 NA before. This should be interested. Also picked a n370 afm, n370 pressure sensor, and rtek chipped N374 ecu (might go with adaptronic later). I'd be happy with 300-350whp.
cristoDathird
28
May 30, 2019 08:47 PM
morataya
Microtech
Aug 17, 2015 01:04 PM
Engine stand ready
Aug 14, 2015 10:26 PM
Turblown
Aug 14, 2015 04:48 PM
