How To: Paint License Plates Lights (SA)
Old Aug 8, 2011 | 03:48 PM
Slandd's Avatar
Not sure if it's the correct term for them, but basically the lights in the back of the rx-7 that illuminates your license plates. Mine were scuffed up and fading so I decided to paint them. Sorry if this is a DIY that's a no-brainer for most of you but I thought I might as well document it if I'm going to be doing it, might help someone else =P.
I took pictures with my iphone so images are not the greatest, will update with other photos later. Btw this is for a '79 Rx-7.
Tools needed: P2 Screw Driver, 8mm socket, 14mm deep socket or open wrench, fairly small ratchet.
Materials needed: Spray can of your choice, clear coat of your choice, sand paper (300/800/1000), rubber gloves if you so choose, and in my case cheap wooden skewers.
1. There are six screws in the back (will add picture later, phone couldn't capture darkness etc) that will need to be removed.
2. You will now be able to see the two 8mm nuts holding up the rear lights. One of them has a ground wire attached to the nut (don't forget to re-attach this when you are done) .
3. Now pull the light out
4. The rubber piece in the back of the lights pull right off. There are two plastic...things...lol...holding the light in place, use the 14mm (I found the open wrench was easiest) to loosen it (I then did the rest by hand).
5. Now you can pull the lights bulbs out and free the casing from the car.
6. Proceed to use sand paper! I started off with 300 grit then moved up to 1000, it's probably overkill but it was laying around so why not.
7. Then tape up the bottom portion of the lights so no paint gets in and tape up the plastic clear cover as well.
8. Then proceed to paint. I've read and experienced several light coats over one big coat. Remember the paint doesn't have to cover all surface areas on the first few run throughs, this tactic can help prevent "the runs." I stuck them on wooden skewers to make spraying easier for me.
9. Wait for it to dry and then put everything back
10. End product
Now onto the next part of my restoration. Hope this was helpful.
Old Aug 9, 2011 | 09:13 AM
t_g_farrell's Avatar
Waffles - hmmm good
Just curious what paint did you use (paint codes from cans if you can)?
Did you do a clear coat on top of that?
Looks nice. Good work.
Old Aug 9, 2011 | 09:25 AM
ray green's Avatar
Gone
Very nice!
One more thing to do, eh Tim?
Old Aug 9, 2011 | 11:39 AM
Slandd's Avatar
Ah to tell you the truth, I would have went with a Krylon Fusion : Flat Black and the Krylon Fusion Clear Coating but those are rather expensive =/ so I just went with a Dupli-color Universal Flat Black DS104 and Dupli-color High Performance Wheel Coating Clear. I got both for $1.50 at my local flea market and couldn't pass it up.
Thanks for the response guys XD
edit: sorry, didn't know the picture was this big.
Old Aug 9, 2011 | 03:45 PM
Waffles - hmmm good
Originally Posted by ray green
Very nice!
Not yet, mine still look minty good. I am about to do the trim tho.
Old Aug 10, 2011 | 12:16 AM
Slandd's Avatar
^^ I have one for the trim XD Back to black turned all my side trims....back to black o.o from mothers. Want me to post before and after?
Old Aug 10, 2011 | 02:27 AM
Directfreak's Avatar
I am a Jeeper Now.
You have to ask? Of Course!
Old Aug 10, 2011 | 09:44 AM
RX-7 Chris's Avatar
I did back to black a few months ago. I liked the way it turned out.
Old Aug 10, 2011 | 09:59 AM
Slandd's Avatar
LOLS sorry I didn't want to seem to nosy. But I will post today, I am ripping off the exterior trim today and using b2b from mothers. I only did one piece in case it didn't work or faded rather than helped.
gabescanlon
Aug 22, 2015 08:31 PM
