How much weight is under the dash?
Old Jul 15, 2002 | 01:04 PM
GLHS's Avatar
Shelby Tuner & FC badass
I wanted to loose more weight and I figured there is alot under the dash.
What can I remove under the dash? I want to keep the dash shell and the guages and keep the fan and defrost/heat. Is there anything under there I can remove?
How much does it all weight?
Thanks again.
Old Jul 15, 2002 | 01:57 PM
dre_2ooo's Avatar
I dunno what all yo can remove.... but the dash is QUITE HEAVY. The glove box door alone weighs 6lbs .
There is THICK Steel plating behind everything. I'd assume it's for crash protection .
Old Jul 16, 2002 | 06:48 AM
GLHS's Avatar
I pulled out the passenger speaker housing and it has 2 wire harnesses that go to small boxes. Can I just unplug these? What are they for?
Old Jul 16, 2002 | 09:45 AM
junior-coyote's Avatar
I took apart a 91 wreck. The dash (plastic part) is reasonably light, not much to save there. There is a metal beam from one side of the car to the other. I suspect it is there to improve crash protection. As I recall, its not very easy to remove, lots of parts around it.
Old Jul 17, 2002 | 02:07 AM
kristopher_d's Avatar
It probably also helps to stiffen the chasis.
Old Jul 17, 2002 | 02:13 AM
brap brap
speaking of weight reduction -
Is there anything else besides taking out the a/c .. and stuff... what else is there to do... to reduce the weight in your car?
Old Jul 17, 2002 | 02:17 AM
jspecracer7's Avatar
1JZ powered
You can take off the bumper and remove the fiberglass bumper support. Go on the inside and remove all trim pieces. Also going to manual mirrors/windows. Remove carpeting...
Old Jul 17, 2002 | 05:23 AM
relvinnian's Avatar
The entire glovebox can't wiegh 6 lbs, what are you talking about? Thick steel behind everything? Seriously, what are you talking about?
Old Jul 17, 2002 | 07:56 AM
dre_2ooo's Avatar
It's true... there is a big thick steel plate in the glove box door, several of them actually.
YES there is steel in there for your protection. go out now and just open your glovebox by letting it drop, i bet it'll break the plastic at the end of the rods. no seriously, it does weigh alot for what it is.
Old Jul 17, 2002 | 08:06 AM
Felix Wankel's Avatar
Super Newbie
I would be afraid of the front bumper caving in under speed with the styrofoam and fiberglass gone. If it won't, that would be cool. Just don't hit anything
I saw a late 70's Camaro with the bumper support removed, and the nose was pushed in so far by the end of the 1/4 (I think it was trapping about 110-120) that the screwed up aerodynamics were probably negating any gain from the weight savings.
Old Jul 18, 2002 | 07:11 AM
GLHS's Avatar
I have had my front bumper and the supports out for atleast 1 years and have done well over 140 mph and I have had no problems with it caving in, or any problems.
MILOS7
May 9, 2016 06:39 AM
Sh00bs
Oct 1, 2015 11:57 PM
vish86
Interior / Exterior / Audio
Oct 1, 2015 11:53 PM
