what hp should i get with my set up
Old Jul 27, 2011 | 03:15 AM
fc-gismo's Avatar
CA what hp should i get with my set up
I got a s5 t2 with a streetport 550 primery 720 sec fmic stock s5 turbo at 15 lbs with a fd uim walborro 255 on a Sprint re standalone just trying to c what i should be at
Old Jul 27, 2011 | 11:40 AM
K-Tune's Avatar
FD Daily
~265whp on a dynojet.
Old Jul 27, 2011 | 05:57 PM
fc-gismo's Avatar
That's not bad ill post up my dyno sheet once i get it dynoed
Old Jul 27, 2011 | 10:48 PM
K-Tune's Avatar
FD Daily
The turbocharger will be your limiting factor as far as horsepower goes.
Old Jul 28, 2011 | 04:19 PM
junito1's Avatar
F**K THE SYSTEM!!
Turbo should reach close to 300whp on streetported engine. I personally think your injectors are the limiting factor along with intercooler.
Old Jul 29, 2011 | 01:18 PM
fc-gismo's Avatar
How big of injectors should and I go and is the front mount not good enough
Old Jul 29, 2011 | 04:50 PM
junito1's Avatar
F**K THE SYSTEM!!
First you need to know what your realistic goal is. Then you want to buy injectors a bit bigger than what you were shooting for. That way you dont ever get close to 100% duty cycle and overheat the injectors.
Hot air intake temps will really limit your HP. I dont know what kit or core you use... but ebay cores suck *** compared to a true garret intercooler core. High boost evo guys prefer the garrett core.
Old Jul 29, 2011 | 08:56 PM
K-Tune's Avatar
FD Daily
I've never seen over 280whp from a stock turbocharger.
Old Jul 30, 2011 | 12:20 AM
sharingan 19's Avatar
Rotary Revolutionary
A friend told me he hit 300whp on the stock turbo w/a microtech; the next week his turbo was blown....
I wouldn't expect more than 265 whp unless a bottle is part of the equation
Old Jul 30, 2011 | 09:10 AM
junito1's Avatar
F**K THE SYSTEM!!
Was he streetported? It makes the difference..
matty
Jan 18, 2020 10:39 AM
