Excessive Engine Heating????
Old Jul 14, 2002 | 08:45 PM
NEED4SPEED'88's Avatar
I have a '88 gxl non turbo.... and the car over heats a little to much. I had the radiator drain and filled with new coolant, put a new 180F-82C thermostat in and the engine has been recently tuned, so timing is right, and the water pump seems to work right b/c coolant circulates in radiator....?? So, what do you guys think??
Old Jul 14, 2002 | 09:47 PM
Scott 89t2's Avatar
SOLD THE RX-7!
what are you basing it on? are you using the stock gauge? what is it at?
Old Jul 14, 2002 | 09:55 PM
Icemark's Avatar
Re: Excessive Engine Heating????
Originally posted by NEED4SPEED'88
Iput a new 180F-82C thermostat in and the engine has been recently tuned,
Uh oh... sounds like not a Mazda thermostat
Only use the Mazda thermostat!
Here's a thread on that same very thing that someone found out today:
http://www.teamfc3s.org/forum/showth...&threadid=2568
Old Jul 14, 2002 | 10:44 PM
I used a Stant brand thermostat... thats hella crappy huh... i should go with a mazda thermostat... where can i get decent one that works right?
Old Jul 14, 2002 | 10:49 PM
what are you refering to Scott, i'm new at the whole rotarty engine..... i don't understand your questions!
Old Jul 15, 2002 | 12:50 AM
Icemark's Avatar
Scott was refering to the stock water temp gauge that is not entirly accurate.
As with most cars, in the RX-7 most of the gauges can be off +/- 5% and be within factory specs, but as the cars age and people fail to maintain them, the senders can go way off. So the stock gauges should be considered something to referance too, but not the most accurate.
Old Jul 15, 2002 | 12:52 AM
Icemark's Avatar
Your local Mazda dealer or online at Mazdatrix or Mazdaformance.com
Old Jul 15, 2002 | 12:42 PM
Thank you guys very much, for helping me understand what could be wrong with this car. I appreciate you help.
C. Ludwig
Jan 30, 2019 06:31 AM
Microtech
30
Apr 23, 2016 06:37 PM
befarrer
Aug 14, 2015 04:18 PM
