Big Block wankel
Old Jul 14, 2002 | 02:14 PM
Talking Big Block wankel
I was wondering the other day what was the largest wankel motor built. I think it would be interesting to see how a 3 or 4 liter would perform. What do you think?
Old Jul 14, 2002 | 02:15 PM
Defprun's Avatar
Punk Ass Bitch
I've seen a Six Rotor, Carburated, no turbos 900hp!!!!
Old Jul 14, 2002 | 02:38 PM
DrKillJoY's Avatar
Administrator
Hurley Engineering in the UK sells up to 6 rotors I think.
Old Jul 14, 2002 | 02:44 PM
82streetracer's Avatar
8/1 Building/Drive Ratio
gm made a rotary corvette concept car. it had a 2.6l rotary.
Old Jul 14, 2002 | 02:56 PM
diabolical1's Avatar
rotary Vette
say ... anybody got some links or sites for those six rotor engines? until now, the 26B was the largest one i've known about. but 900HP on carbies ... christ! that's fantastic!!!
i wish i was a millionaire ...
Old Jul 14, 2002 | 03:28 PM
take a look at the road and track or car&driver,
whichever one has the 50 years of the Corvette issue.
in the artical about failed vettes there is a really ugle one that had a rotary engine.
a 2.6 L rotary would sound tight as hell.
Old Jul 14, 2002 | 03:50 PM
just in case ... i want to let you know that i wasn't trying to attack you ...
it's just when i think of GM going public with "ideas" of using a rotary engine ... i feel like i just got pee'd on by a homeless guy with gonorrhea or something ... that's all ...
peace
Old Jul 14, 2002 | 10:19 PM
SunRedRX7's Avatar
I have found the largest Rotary Engine I believe.
http://www.pegasuspower.com/SpecSheet/580rot~2.pdf
34.7liters, 6 Rotors, and 3000HP, so maybe its meant to be a generator not a car engine.
Rotary Power International's website
Old Jul 15, 2002 | 02:31 AM
Vohaul's Avatar
did you see the weight of those things.....??
good grief the 6 rotor weighs a lot more than my entire car
Old Jul 15, 2002 | 03:05 AM
ioTus's Avatar
'84 5-letter
I think insted of doing a TII swap i'll just get the 3000 hp engine
Hurley UK:
http://www.hurley-engineering.ltd.uk/
The built a custom 3 rotor engine there, not too sure why that would be better than a 13b tho....
Old Jul 15, 2002 | 03:06 AM
RotorMotorDriver's Avatar
Seven Is Coming
I have seen that beast before...I had it under the hood of my car, but she didnt pull as hard as I wanted it to above 12,000 RPMs, so I sold it off to this company and bought myself a real car, 1983 GSL .
~T.J.
Old Jul 15, 2002 | 03:35 AM
BrianHeston's Avatar
Beware Of Squirrely Wrath
Did anyone notice the length of 116 inches? Thats longer than our cars... More than 11 feet.
BrianHeston
Old Jul 15, 2002 | 03:58 AM
peejay's Avatar
Old [Sch|F]ool
Mazda had prototype 21A/22A two-rotor engines for the 240Z fighter they were going to make, before the oil crunch killed that idea. Much larger trochoid dimensions than the 10A/12A/13B/20B/R26B engines.
I consider a "big block" anything to me larger in all dimensions... for a piston engine this means the deck height is larger and the bore spacing is larger. For example, the 396 Chevy is a big-block because it has much lerger bore spacing and deck height than the small-block, even though its displacement is smaller than the largest small-block (400cid). The Dodge truck V10 and the Viper V10 are small-blocks in my mind because they are the same dimensionally as the 318/360 (technically, the Viper is based on the 318/360 and the truck engine is based off of the more modern 5.2/5.9( it just has an added pair of cylinders.
Old Jul 15, 2002 | 10:14 AM
Hans's Avatar
right, but a wider rotor face would lower compression right?, how much is there left to push against the housing? i guess you could do a really wide rotor with a big blower, or turbo since compression would be complementary
correct me if im wrong, but thats how i be seeing it working
Old Jul 15, 2002 | 10:47 AM
peejay's Avatar
Old [Sch|F]ool
A wider face wouldn't lower compression unless you widen only the middle where the dish is.
Likewise, if you keep the dish the same size, widening the rotors will cause compression to increase.
Old Jul 16, 2002 | 12:04 AM
Hans's Avatar
i see says the blind man, after i posted i kinda wondered about that, but didnt want to try and real world model it for my dumb brain
Old Jul 16, 2002 | 02:51 AM
Manntis's Avatar
add to cart
Terms like "motor" are flexible even though some insist that "engine"is correct for mechanical and "motor" for electrical (were that so, how are sales at General Engines and Ford Engine Company?)
In contrast terms like "big block" or "small block", or the definition of displacement, have more specific meanings. For the purpose of concise communication, especially when dealing with engineering issues such as automotive mechanics and all the associated bits that make physical or financial owies if tinkered with incorrectly, it's important that well-defined terms not be assigned elastic or relative meanings.
Old Jul 16, 2002 | 03:10 AM
ok, sorry about that
Old Jul 16, 2002 | 03:40 AM
Manntis's Avatar
add to cart
that was a quote from peejay's post, jalvord. NOt that I'm giving anyone in specific sh*t, just trying to keep communication clear.
Old Jul 16, 2002 | 03:48 AM
ok, i hear you
Old Jul 16, 2002 | 04:46 AM
peejay's Avatar
Old [Sch|F]ool
Well, exactly. Big block and small block are relative to the size of the basic engine and have little to do with displacement. Take a look at, say, a 351 Windsor (small block) versus, say, a 332 FE (big block), or a 400 Chevy (small block) against a 366 Chevy (big block) and you'll see my point.
So a 21A or 22A would be a big block Mazda, since they were huge in relation to our little 10A/12A/13B engines.
Old Jul 18, 2002 | 12:32 AM
Directfreak's Avatar
I am a Jeeper Now.
Old Jul 18, 2002 | 02:48 AM
peejay's Avatar
Old [Sch|F]ool
Exactly what I'm talking about.... notice the 12A and 15A are the same size except for width... they're the same trochoid dimensions - same "block" just lengthened. (A 15A would have been a 13B with 10mm wider rotors just as a 13B is a 12A with 10mm wider rotors etc - 10A 60mm, 12A 70mm, 13B 80mm, 15A 90mm) The 21A is just enormous.
jarjarbinks
Sep 25, 2015 11:03 PM
MidnightOwl
Sep 25, 2015 10:24 PM
RedBaronII
Sep 20, 2015 11:29 AM
ray green
1st Gen General Discussion
Sep 2, 2015 06:35 AM
