Drifting Discuss Drifting and drifting techniques here.
Front Diff mount!!!!
Old Jul 5, 2011 | 01:47 AM
Dirt-McGirt's Avatar
I eat them like candy. Lets here what you guys are doing to solve the problem. I have busted 3 and tore the tab off my old subframe twice. Im ******* over it.
I can make almost anything at my new work and im thinking of a solid unit...
I run a fully built subframe and Delrin diff mounts, stock, beat *** lower crowns. I like alot of grip in my setup. Pinion snubber has been in for the past 2 mounts.
What are you guys doing for this, its annoying as FACK.
Old Jul 5, 2011 | 02:25 AM
S2-13BT's Avatar
Are you preloading your pinion snubber on the diff or no?
Old Jul 5, 2011 | 02:48 AM
Zenki FC3S's Avatar
\\TRASHTALK//
Dude,box it in with 3 plates... Pound till flush and TIG or MIG
Old Jul 5, 2011 | 04:18 AM
RotaSpinna69's Avatar
^THIS or...
https://www.rx7club.com/group-buy-product-dev-fc-rx-7-268/fc-semi-solid-diff-mount-938333/
...I thought that was neato!
FOUND IT!
http://www.norotors.com/index.php?topic=3659.0
Old Jul 5, 2011 | 05:49 PM
leftcoastdrifter's Avatar
Dustin Becktold
went through three in three drift events, put in a Nissan truck bump stop and bam, no more broken mounts. It's hella preloaded, that's the key.
Old Jul 5, 2011 | 06:02 PM
RotaryEvolution's Avatar
Sharp Claws
also depends on the material the stop is made out of as to how much give it will have.
Old Jul 5, 2011 | 10:46 PM
Justen's Avatar
If your gonna box/weld the front mount like Zenki said, make sure you preload the **** out of the pinion snubber so you dont shear again.
I'm thinking of putting a second bump stop on mine somewhere... if i can make it work
Old Jul 5, 2011 | 11:32 PM
papiogxl's Avatar
What's the point??
I like the thought in that second link spinna posted, but I think it would be better to use something like a clevis and sway link instead of the ghetto oversized hole.
Old Jul 6, 2011 | 11:04 AM
^I agree on the sway link
BNR34RB26DETT
42
Feb 28, 2018 11:27 AM
fidelity101
13
Aug 31, 2015 07:47 PM
