88 na in 86 sport will it work ?
Old Jul 14, 2002 | 10:56 AM
can i put an 88 na motor in my 86 sport? will the 86 ecu run the 88 motor with no mods to the harness or do i need to run the 88 ecu instead of the 86 ecu?
Old Jul 14, 2002 | 11:02 AM
Aaron Cake's Avatar
Engine, Not Motor
Yep, it'll work. However, you will need to swap the injectors from the 86 engine onto the '88 engine. Or, bypass the resistor block on the '86 wiring harness.
Old Jul 14, 2002 | 09:45 PM
Thanks Aaron for the help, can you give me a general location of this resisitor block i need to bypass. or would you recomend just changing injectors?
Old Jul 14, 2002 | 09:47 PM
fc3s.org's Avatar
OG
It is right by the passenger side headlight. Looks white in color usually from what I have seen.
Old Jul 14, 2002 | 09:59 PM
Felix Wankel's Avatar
Super Newbie
The resistors themselves are whitish, but the cover to it is aluminum.
You have to pull the airbox off to see it.
Old Jul 14, 2002 | 11:35 PM
powermalex's Avatar
What are the resistors for?
Any comments about installing a ported engine in my 86 Sports RX-7
Old Jul 15, 2002 | 12:07 AM
Silkworm's Avatar
Has been.. hangin' around
Just swap the injectors, its' a hell of a lot easier.
Everything else should just bolt in, no problem.
PaulC
Old Jul 15, 2002 | 12:10 AM
Super Newbie
PaulC
Thats what I would do. Swapping NA injectors is a cakewalk.
Old Jul 15, 2002 | 10:19 PM
Ok, thanks guys, think i will just swap out the injectors, i assume that means all 4...
Old Jul 16, 2002 | 01:23 AM
Silkworm's Avatar
You got it.. All 4
rotor_veux
46
Jun 12, 2018 10:39 AM
82streetracer
Aug 23, 2015 09:28 AM
