WARNING to those with an HKS AFR!!
Old Jul 14, 2002 | 10:42 AM
Drakk0r's Avatar
As you've all probably seen, I've been having trouble getting my car running right after my turbo install. One of the things I checked was my wiring for my AFR. Everything was exactly as the instructions say. So I'm reading the Factory Service Manual, and find that the instructions have you tap into the pressure sensor wire to modify the fuel curve! NOT the Air Flow Meter as it should be. I recommend downloading the S-AFC directions and using them for the AFR. They use a different ground point, but at least it uses the right signal wire. Just thought I'd let everyone know.
Old Jul 14, 2002 | 11:37 AM
HuggyBear's Avatar
you should tell hks. save the next guy some trouble.
if u already have, then disregard
Old Jul 14, 2002 | 01:47 PM
Aaron Cake's Avatar
Engine, Not Motor
Yikes! So it's running alright now? Let's see those pictures and videos...
Old Jul 14, 2002 | 07:33 PM
Barwick's Avatar
SCCA Rookie
wow they could get into some serious trouble like that
Old Jul 14, 2002 | 08:39 PM
Drakk0r's Avatar
Yeah... My car isnt running right even after I fixed it... If any damage resultedfrom it they can expect a lawsuit... I'm ruling out other options now..
93FD510
Oct 1, 2015 02:00 PM
