Radar Install
Old Jul 12, 2002 | 03:40 PM
PVerdieck's Avatar
Radar Install
I looked but couldn't find a related thread.
Anyways, I am going to install my Valentine-One this weekend. I want to parasite off of a switched wire.
Which would you recommend? What is the easiest.?
I don't want to have a dumbass cord running down to the cigarette lighter.
Old Jul 14, 2002 | 02:44 PM
PVerdieck's Avatar
Talk about overwhelming, I don't know what I will do with all this feedback!
Old Jul 14, 2002 | 02:52 PM
Zoomspeed's Avatar
the prevous owner of my car, ran the plug from where the radar detector would mount, thourgh the head lines, and down the inside of the a=piller to somewhere.
First chance I get I'll see if I can follwo the wire and see where he spliced it.
Old Jul 15, 2002 | 07:32 AM
TailHappy's Avatar
Addicted to Track
Sorry, I can't remember the exact wire I used for my V1. Just go buy a testor with a lightbulb in it for a couple of dollars and start at your fuse box and see which wires are switched. Seems like there were only two, so it wasn't much of a decision......
Old Jul 15, 2002 | 08:43 AM
PVerdieck's Avatar
Yeah, I was thinking of running it down the A-Pillar also.
Old Jul 15, 2002 | 09:24 AM
grampa's Avatar
I mounted mine on a flat metal bracket above the rear view mirror to keep it out of view. The bracket is a flat SS plate that mounts under the clip bracket that holds the dome/map light in place. In this location it is much easier to hit mute that when on the windshield.
I have the remote display mounted just between the steering column and cigarette lighter socket. Using the V1 power hardwire connected to the upper left male spade connector in the fuse block above the dead pedal. This male spade is powered when ign is on.
24seven_dada
20
Nov 10, 2018 12:03 PM
sinclair7seven
11
Sep 11, 2015 10:15 AM
astrum
Sep 7, 2015 11:41 PM
Enzo1944
Sep 6, 2015 08:57 AM
