Megasquirt high rpm detonation ignition?
Old Jun 19, 2011 | 05:49 PM
gabs88gxl's Avatar
Retard
Ok so I am having a major pain in my but right now. I have a half bridge fc with a 2.2v megasquirt the o2y9 i think thats how its spelled out but thats the filmware in it an all that fun stuff.
The problem is this. When i drive the car it runs fine idle is ok for a half bridge. But the main problem is when i hit full boost 12psi i get up to about 6-7300rpm an just cuts out bucks detonates. Then if I pull second it feels like it will boost then just get very sluggish n backfire n buck again. My air fuel is at 10.9 in full boost. I have a good timing map from 13bdarren.
Things i was thinking that it might be,dwell is wrong or there is a different set up for a hbp. Or maybe something else that would cause a ignition mishap in a high rpm tooth settings so on. please can anyone help i hate this
Old Jun 19, 2011 | 06:02 PM
gabs88gxl's Avatar
Retard
tune zip
File Type: zip
Old Jun 21, 2011 | 04:48 PM
Jobro's Avatar
SAE Junkie
13psi @ 7400rpm is the highest i was able to semi reliably light with factory ignition system.
Consider replacing your BUR7EQ and BUR9EQ for R7420-9.
That will drop the spark gap and keep the resistor $$$$ tho.
Old Jun 23, 2011 | 01:19 AM
gabs88gxl's Avatar
Retard
well see that was the thing is i had a msd on there an it was still doing it. i also have a aem twin fire dont bash on it it hasnt givin me any problems the reason i took it off was cause i couldnt figure out why it was doing this
SakeBomb Garage
Vendor Classifieds
Aug 9, 2018 05:54 PM
13
Jan 9, 2018 11:19 AM
gxl90rx7
Haltech Forum
Sep 14, 2015 03:09 PM
msilvia
15
Sep 11, 2015 12:13 PM
