trying to beef up alternator
Old Jul 12, 2002 | 01:29 PM
Ryde _Or_Die's Avatar
Well my alternator seems to be on its way out so I want to have it rebuilt and upgraded. I called a few places and one place said they don't make any kits for it to be upgraded but they might be able to get a "delco" aftermarket one on. They said they have a 105amp one or a 140 amp one. The 105 will cost me $170 and the 140 will cost me $280. What does the stock one have? Anyone have any better ideas? I know the stock ones are weak and I don't even have a radio in yet and I'm having a problem. I plan to have a stereo(possible 500watt amp), s-afc, turbo timer, gauges, boost controller, etc put in soon. Thanks alot. Oh and what does the FD one put out? Thanks alot.
Old Jul 12, 2002 | 03:03 PM
FC Drifter's Avatar
Damaged Little F*cker
get one off a 3rd gen. they are supposed to be way better than the 2nd gen ones. i think someone posted a link here a while back on how to do the swap. try a search to find out. i looked on car-parts.com and FD alternators are like 150 bucks so thats not too bad.
Old Jul 12, 2002 | 03:27 PM
Aaron Cake's Avatar
Engine, Not Motor
Put an FD alternator on. All you need to do is change the pully and a little wiring. As I recall, they are 100A units.
Old Jul 12, 2002 | 04:48 PM
I can get an FD one for like $40 I think. The pulley I can do, but what about the wiring?
Old Jul 12, 2002 | 04:56 PM
vmb
do a search dude!
Old Jul 12, 2002 | 05:06 PM
jspecracer7's Avatar
1JZ powered
Big Aaron's right on the money. Being a previous FC owner, and knowing that the FC only puts out 60A's vs. 100 A's from the FD...and all you'll need to do is change the pulley(just need an impact gun) and the wiring...piece of cake!
Old Jul 12, 2002 | 05:52 PM
NZConvertible's Avatar
I'm a boost creep...
The S4 alternator put out 70A, the S5 80A, the FD 100A. Do a search, the how-to links have been posted dozens of times.
Old Jul 12, 2002 | 05:56 PM
I wish I was driving!
I'm looking to put a 200 Amp Alternator on my next engine. I'm going to have a few High-current drawing accessories, and overkill is beatiful.
Might wind up with a 140 amp though. I'll have to see the requirements.
On a similar note, has anyone notcied Summit's price on the Meziere street electric water pump? $288! I think its time for an order.... (yes I know I need the mounting kit)
Sean Cathcart
Old Jul 14, 2002 | 01:06 AM
Silkworm's Avatar
Has been.. hangin' around
will it fit an FC?
Old Jul 14, 2002 | 01:23 AM
Originally posted by Silkworm
will it fit an FC?
Not in the stock location...
But my motor isn't going to fit without custom work either...
Old Jul 15, 2002 | 05:26 PM
rx7_ragtop's Avatar
From: Ft. Worth, Texas, USA, Earth, Solar System...
www.geocities.com/rx7_ragtop
Go to "my car and mods" and click on the link about the alternator.
Essentially, you have to make 2 "jumper" wires about 6" long. Male spade connector on one end, female on the other. The one to the black wire (black with stripe?) goes on the top connector on the alternator.
You have to find a v-belt pulley for a 17mm shaft or drill out your existing one (and the spacer.)
Brad
Old Jul 15, 2002 | 06:39 PM
Ok for now I'm getting a S5 alternator. Is it a direct fit for my S4 though?
zyph3r
Canadian Forum
Sep 16, 2018 07:14 PM
Robrods64
Oct 2, 2015 07:56 PM
WANKfactor
Sep 29, 2015 01:14 PM
