poor compression
Old Jul 11, 2002 | 07:49 PM
goffredo6218's Avatar
poor compression
hey everyone help with my rotary,what are all the possible causes of low compression in a rotary that is running.only poor for #2 rotor.are they all tear down issues?i read some posts talking about secondary intake ports that open etc.could this be stuck open and cause it?its an 88 non turbo and if i have to tear it down what bolt on mods would you all suggest to build more streetable power [other than nitrous]thanx for the input.
Old Jul 11, 2002 | 10:08 PM
turbo II addict's Avatar
for bad compression it could be bad carbon build up around the apex seals
Old Jul 11, 2002 | 10:25 PM
If it is carbon buildup you could do the ATF treatment or it may be a blown engine which would require a complete teardown and rebuild of the block. If you are going to rebuild it you might want to go with a port job since the only time you can do that is when the engine is apart.
turbodreamz22
28
Nov 10, 2023 11:08 AM
Turblown
Vendor Classifieds
Oct 17, 2020 03:25 PM
Andrew7dg
Aug 6, 2017 01:41 PM
