just a click?
Old May 21, 2011 | 12:11 PM
sqwat's Avatar
Unhappy just a click?
ok so i have a right hand drive FD and everything has been running great until now! i put the key in and turn it, fans, dash, radio the whole works comes on in the car but when i go to turn it over i get a click and thats all. the car did die coming home from work last night for a few seconds then came back no issues. i was just driving down the road and all of a sudden everything turned off then came back. got it home and now it just wont start
Old May 22, 2011 | 10:21 AM
Aaron Cake's Avatar
Engine, Not Motor
Sounds like you have some major wiring issues.
Check for loose connections and frayed wires around the main fuse box at the front of the car.
Check both battery terminals for tightness as well as the main grounds.
Old May 22, 2011 | 11:14 AM
mistermorgan's Avatar
mmo devotee
wont turn over
Check the starter solenoid.
First, are wires tight ,then
Only if necessary remove starter and have the solenoid and starter examined at a competent auto shop or parts retailer (e.g U.A.P)
As far as the big shutdown goes ,I think the problem might be as simple as a loose battery connection.
Anyhow check the obvious probable culpabilities Then worry about the more serious ones.
That might be a fart and not a **** in simple crude terms.
Old May 22, 2011 | 11:45 AM
snivley whiplash's Avatar
brappppp brappppp
battery and grounds are the most important, check the battery connections first, CLEAN and tight
Old May 23, 2011 | 10:25 PM
turbodreamz22's Avatar
+1 on battery. if its loose even a little bit, it could do something like that.
Old May 24, 2011 | 11:00 AM
sqwat's Avatar
thanks for the tips guys
i was away for the long weekend here so i will get a chance to look at it tomorrow
i will keep you up to date on how it goes
but how would a loose battery connector cause it to rev up and down like that? shutting off i understand but.....
like i said i will let everyone know how it goes...i will probably need ore help
im very new to this
cheers guys and thx
Old May 24, 2011 | 01:35 PM
Zero10's Avatar
Rev up and down like what? You didn't say anything about it revving up and down, just that it shut down for a second and came back, which loose wires at the starter solenoid, under-hood fuse panel or many other places may cause.
Old May 25, 2011 | 09:12 PM
sqwat's Avatar
Wow I feel like a complete dubass -_- after it cut out and came back ... The whole way home it reved between 2000rpm and 2500 rpm when idling
Old May 27, 2011 | 09:59 PM
sqwat's Avatar
ok so it was the starter thx for all your help guys, im new to all this so sorry for being such a nub
cheers
ArmAnirx7
West RX-7 Forum
35
Mar 8, 2021 12:54 AM
msilvia
164
Mar 8, 2020 08:00 PM
sccarally
South RX-7 Forum
Oct 8, 2015 05:27 PM
Smokeyfb33
Old School and Other Rotary
Oct 1, 2015 12:10 PM
poop2003
Sep 21, 2015 10:28 PM
