Sitting for 6 years. Fuel pump will not come on. Need HELP!!!
Old May 16, 2011 | 04:21 AM
DC2Kris's Avatar
TN Sitting for 6 years. Fuel pump will not come on. Need HELP!!!
I just bought a 93 touring model. It has been sitting for 6 years.
I drained the gas. Put MMO in the spark plug holes for a week and kept rotating it and adding MMO each day and spinning it. Bought a new battery, made sure it was fully charged. Added 5 gal of fresh gas.
The fuel pump will not come on. I tried jumping the connection at the diagnostic box and the fuel pump still will not come on. The W/R wire gets power at the fuel pump when diag is jumped, but when it is not jumped, it does not get power.
Checked all the relays and they are clicking and coming on.
It cranks over easily, but no fuel pump.
Need some help.
I am ordering a new fuel pump and fuel filter tomorrow.
Old May 16, 2011 | 10:38 AM
rxtasy3's Avatar
not much on fd's but have u tried running +12v straight to the pump? and make sure it's getting a good ground. could just be a bad pump.
Old May 17, 2011 | 03:48 AM
DC2Kris's Avatar
I pulled the pump and ran it directly to the battery and it is dead. Well its more seized up. Hopefully that is the only issue.
Old May 17, 2011 | 04:58 AM
dgeesaman's Avatar
Hopefully you didn't order a stock fuel pump from Mazda. Used one will work fine for $30.
To test the fuel pump within the stock wiring, use the small black box between the battery and wheelwell. Open it and insert a solid wire (paper clip) to jumper between the "F/P" terminal and any position marked "GND". When you key on the fuel pump should run full time. While you're waiting for your new pump you can at least try this to verify the wiring is functioning correctly.
David
Old May 17, 2011 | 07:26 AM
Brent Dalton's Avatar
Sua Sponte
Where at in TN are you located?
Old May 17, 2011 | 01:16 PM
DC2Kris's Avatar
Hey Brent,
I'm in murfreesboro. I met you at the NSS once during a track event. I drive a black 2000 Acura Integra with a TypeR wing.
I thought about seeing if you had time to bring one of yours by one day so I could look at your rat nest to find out where a few vacuum lines go to.
Do you have any spare parts or used original parts for the rx7?
Old May 17, 2011 | 01:18 PM
DC2Kris's Avatar
David
I did this procedure while the pump was in the car and when I put the jumper in I would get power at the plug, but when I put the plug in, the pump would not come on.
New pump should be here today.
Old May 18, 2011 | 12:54 AM
Sua Sponte
Originally Posted by DC2Kris
Hey Brent,
Cool! I do, but I live in GA currently. If you are needing stock parts, just let me know what you are needing and I'll dig through my stuff. Chadwick on the forum is the guy to see in our area to get work done. He has a day job that is keeping him pretty busy M-F currently, but he might have a weekend or two open between races if you need some work done. He has a shop in Smyrna.
Old May 18, 2011 | 12:58 AM
BStallion's Avatar
unleashed
Good luck changing the fuel filter..
Old May 18, 2011 | 02:54 AM
DC2Kris's Avatar
haha ya.. I started to give it a shot tonight, but said F-that once I seen how hard it was. It wasn't something I was going to start messing with at 3am after working on the CR-V all night.
I'll try tomorrow.
Old Jun 26, 2011 | 04:44 PM
DC2Kris's Avatar
Fuel Pump not coming on
I have a 93 TT. I just bought it almost 2 months ago. The fuel pump will not come on when the key is turned. I put a new fuel pump in and it still will not come on. When I jump the DIAG connector under the hood, it comes on when the key is turned.
Any ideas? I checked fuses and swapped relays but no luck.
Just need someone to point me in the right direction as this is my first rotary.
Old Jun 26, 2011 | 07:25 PM
BomberMan's Avatar
No clue about FD's, but I dare say you need to give more info if you want any specific advice.
Or you can troubleshoot it yourself:
http://foxed.ca/foxed/index.php?page=rx7manual#thirdgen
Old Jun 28, 2011 | 10:32 PM
gracer7-rx7's Avatar
needs more track time
Well, apparently it wasn't the fuel pump, eh.
What makes you think its the fuel pump? How are you testing it? Do you see and hear it working with the key or Diag?
Old Jun 29, 2011 | 12:57 AM
DC2Kris's Avatar
It works with Diag jumped. I started troubleshooting it some more tonight but got sidetracked.
Old Jun 30, 2011 | 01:35 PM
Hector2JZ's Avatar
check if the main relays clickin because if you have a bad ground then it will not click and the fuel pump will not work .just check your grounds
cristoDathird
28
May 30, 2019 08:47 PM
Rotospectre
Mar 28, 2018 03:33 PM
alphawolff
Nov 17, 2015 05:57 PM
