Rotary Drag Racing The place to post your racing stories and info
Can someone recommend where to get a clutch?
Old May 14, 2011 | 09:21 PM
Doc Holiday's Avatar
Needs more cow bell
PPort 13b on nitrous with a T2 trans. 4 link car. Trans is currently stock so I need to try and shift this hunk of junk at 10k with the syncros still in it. Im thinkin an unsprung disc, perhaps a 3 or 4 puck? Any suggestions on what to get and where? I appreciate it.
Old May 14, 2011 | 09:59 PM
sk8world's Avatar
Chasing numbers
Act 6 puck unsprung. If you just need a disk I have a few that I had repucked. There is a new material that I am running that is great, if you ask them you might be able to score one but I know they have a bunch of the older ones they need to clear out first.
Old May 14, 2011 | 10:33 PM
RoTaRyBoYz's Avatar
InsaneRotaries.com
I have a NEW (still in box) ACT 6 puck & aluminum flywheel somewhere on my engine shelf... It's been there for 4-5yrs now and I have no plans to use it.. Let me know if it's something you might be interested in, then I'll go looking for it
Old May 15, 2011 | 12:21 AM
Needs more cow bell
Id perhaps be interested in the clutch but not the flywheel. Part # off the clutch?
Old May 15, 2011 | 10:35 AM
Needs more cow bell
Aren't 4 pucks lighter and therefore easier to shift than 6 pucks?
Old May 15, 2011 | 10:39 AM
sk8world's Avatar
Chasing numbers
I went over this with act and they still insisted I would be better off with a 6 puck unsprung. Give them a call, very helpful guys.
Old May 15, 2011 | 11:06 AM
rotorious13b's Avatar
sintered iron disc with a good pressure plate you good, funny car style disc .... the more heat they build the better they grab
Uploaded with ImageShack.us
Old May 15, 2011 | 03:58 PM
ultimatejay's Avatar
The fewer the number of pucks the more the clutch will grab. On my 12abp I used the Racing beat unsprung 4 puck and Exeddy heavy duty pressure plate and had good results. I am now using the cintered iron disc like Joe is recommending and that too would work good but you would have to have one custom made for your input spline and diameter. You should be fine with either the 4 or 6 puck with a heavy duty pressure plate.
HalifaxFD
Canadian Forum
126
May 9, 2016 07:06 PM
risingsunroof82
Sep 9, 2015 08:06 PM
