how can you make a rex more dependable?
Old Jul 10, 2002 | 07:59 PM
RiceRocket's Avatar
Livin loud like TIMMAAAYY
how can you make a turbo 2 more dependable? and yes i knwo it may be a broad question
Old Jul 10, 2002 | 08:44 PM
banzaitoyota's Avatar
What Subscription?
Replace all the coolant hoses, flush yor radiator and oil cooler, replace your oil cooler lines with s/s. Make sure all shrouds are intact and installed right. Switch to EVANS NPG+, Ditch the OMP, run premix.
CHANGE YOUR OIL EVERY 2.5K miles!!!!
Old Jul 10, 2002 | 09:01 PM
RETed's Avatar
Buy a Toyota!
-Ted
Old Jul 10, 2002 | 09:04 PM
AJatx's Avatar
Ted, uhhh he said his T2.
Don't race it. (Yeah, I know.... unreasonable).
What banzai said... along with buying a daily driver.
just kidding, man.
You may want to change out your vacuum lines with silicon or new ones.
J
Old Jul 10, 2002 | 10:13 PM
autocrash's Avatar
Now with more 1st Gen!
Originally posted by RETed
Buy a Toyota!
-Ted
so true... toyotas last forever!
TOYOTA POWER!!!!
Old Jul 10, 2002 | 10:17 PM
chrispapas's Avatar
or a nissan
Old Jul 10, 2002 | 10:19 PM
autocrash's Avatar
(old loyalties)
Old Jul 10, 2002 | 10:21 PM
CrackHeadMel's Avatar
Learned alot | Alot to go
or or i know it hurts
hondah, i had one and it was reliable.. untill it met a tree
Old Jul 10, 2002 | 10:56 PM
RiceRocket's Avatar
well, my rex isn;t my daily driver, my truck is, but i want it to be dependable on my weekend road trips
Old Jul 11, 2002 | 12:00 AM
autocrash's Avatar
Hmm... just take good care of it then... coolant changes, oil changes... filters... etc..... and ur wankel will be happy!
Old Jul 11, 2002 | 01:14 AM
jmseven's Avatar
Asset is Wealth
To add. If you have mods, just make sure that the ECU that you are using is tuned properly (close to 14.7 mixture) as possible. The ratios must be close for TOTAL reliablity.
Make sure that you have NO leaks anywhere. If you car is tight and well kept, you will have YEARS of fun.
Old Jul 11, 2002 | 05:31 PM
vaughnc's Avatar
knowledge junkie
This has all been covered before, so do a search for "reliability" or "maintenance" or "dependable" and you'll find LOADS of information:
Off the top of my head:
Get the FULL 60K mile service done (fuel injector cleaning especially).
At 85-95K miles replace the TPS, upgrade the exhaust (downpipe to replace the pre-cat, performance main cat, catback exhaust).
Switch to redline synthetic in the transmission & rear differential (stay with regular engine oil in the engine).
Engine stand ready
Aug 14, 2015 10:26 PM
