88 vert manual gear ratio
Old May 6, 2011 | 02:16 PM
Pimped_RX7's Avatar
hi im droping a lt1 in my vert and need to know what the gear ratio is on a '88 vert manual trans. so i can have my pcm programed to read right speed.
Old May 6, 2011 | 04:06 PM
RotaryRocket88's Avatar
Top Down, Boost Up
The '88 brochure has gone missing from the thread, but here is the '87 one. The ratios are the same: https://www.rx7club.com/showpost.php...21&postcount=3. By the way, an NA transmission is not going to put up with V8 torque for long.
Old May 6, 2011 | 07:54 PM
Pimped_RX7's Avatar
im just looing for rear end realy didnt know if gear ratio is differnt from auto to manual. ive got 4l60e for trans
thanks
Old May 6, 2011 | 07:57 PM
Pimped_RX7's Avatar
yeah i found that page but whats the rear ends gear ratio??
Old May 6, 2011 | 08:15 PM
lastphaseofthis's Avatar
My job is to blow **** up
all S5 verts have 4.101 to 1. auto or manual.
The only year the s4 vert was made was the 88.
you could get under the car and mark the flange and housing, and then count 4 turns of the tires, if the driveshaf tmark is before the houseing mark, after 4 turns, then it's a 3.909. if the driveshaft mark is after, the it's a 4.101.
Which is all pointless as you'll likely blown the N/a rear with any kind of hard launch.
Old May 7, 2011 | 01:15 PM
Top Down, Boost Up
Rear end ratios are on that page too. Right below the transmission ratios.
Unless swapped, all '88 verts had 3.9 open diffs.
Old May 7, 2011 | 01:17 PM
Pimped_RX7's Avatar
yeah the rear end is lincon locked so im not worryed about the diff just the snub shafts. i dont know who is right but theres a lot of posts that say the n/a will hold the power of the v8 and some people say it wont. ill just have to give it a try.
Old May 7, 2011 | 01:20 PM
Top Down, Boost Up
The half shafts have been snapped by engines with only ~150 wtq, but they were beat on. I can tell you that the NA diff in my car has held up fine for 20,000 miles with ~250wtq.
Old May 7, 2011 | 01:26 PM
Pimped_RX7's Avatar
thats good becouse the lt1 has 330wtq i have a spare thierd member when i break this one.
Old May 7, 2011 | 06:08 PM
I don't see the information. i only see 87 and 89!
Old May 8, 2011 | 04:13 PM
Top Down, Boost Up
As I mentioned, the '88 brochure image is gone. It was hosted somewhere on Icemark's site. So you just have to take my word for it . The S5 convertibles all switched over to 4.1 open rears.
20B Forum
21
Mar 22, 2022 01:00 PM
rgordon1979
40
Mar 15, 2022 12:04 PM
24seven_dada
20
Nov 10, 2018 12:03 PM
MikeTee55
Sep 8, 2015 08:05 PM
