Lower Intake s5 N/A
Old May 4, 2011 | 04:59 PM
PSTNLESS's Avatar
Lower Intake s5 N/A
Im posting this in new member technical, in hopes of finding the answer with out getting torn to shreds,,,lol Now I know how to use the search function and have read countless hours, of outstanding information,,, I need to know if I can take this off with out removing the upper intake, and also what gaskets will i need to replace? The lower gasket to the keg for sure,,, how about the one between the lower and upper intake? Thanks in advance!!! David
Old May 4, 2011 | 09:11 PM
RotaryRocket88's Avatar
Top Down, Boost Up
The UIM must come off; they're connected.
You will need to replace the gasket between the LIM and block, and the gasket between UIM and LIM. While you're in that area, you may as well replace the fuel lines. Use only high pressure 5/16" fuel injection line. Generic, low pressure fuel/emissions hose is not recommended. You can replace injector o-rings and grommets at the same time.
Old May 7, 2011 | 09:56 AM
PSTNLESS's Avatar
Thanks for the response,,, I just received my Pineapple sleeve inserts Now I just need to get all of my gaskets , grommets, and o rings ordered !!! I think I can get the fuel line at the auto parts store?? Again thanks for the help,,,
Old May 7, 2011 | 01:17 PM
Top Down, Boost Up
Yes, I bought some 100 psi rated fuel line (SAE 30R9 I think) at NAPA awhile back. The generic hose you'll find will be SAE 30R7, which is rated for only 50 psi & not intended for fuel injection.
jsesq
27
Sep 25, 2015 11:10 AM
