flywheel without starter teeths?
Old Jul 10, 2002 | 02:52 PM
hIGGI's Avatar
http://www.horsepowerinabox.com/imag.../fw22_01lg.jpg
i just got this flywheel, but how the **** i`m gonna start my car ????
Old Jul 10, 2002 | 02:53 PM
adamlewis's Avatar
Back from teh deadly!
Push it.
Old Jul 10, 2002 | 03:04 PM
hIGGI's Avatar
haven`t been mentioned its only for push-start cars...damn, i`m fucked up now..
Old Jul 10, 2002 | 03:10 PM
hIGGI's Avatar
here is stuff i got from Tim :
http://rx7cz.net/temp/aus/
Old Jul 10, 2002 | 03:48 PM
WonkoTheSane's Avatar
Green Flameless
are you sure you don't just take the starter ring off of the old one? taht's the way it was on my eclipse.. i got it off fine, but you have to heat it with a torch and pound the hell out of it to get it back on, i couldn't do it, my mechanic did it in a few minutes, tho...
Old Jul 10, 2002 | 04:08 PM
RETed's Avatar
I find this a disturbing trend.
Maybe the folks down under hand a different definition on what exactly a replacement "flywheel" is considered?&nbsp I would at least expect some explicit instructions to warn the potential buyers that the ring gear needs to be swapped.&nbsp I don't think this is stated on the website, and I'm sure hIGGI wasn't warned either in any of the email replies.&nbsp This would explain the cheap price on the unit.&nbsp Ring gear swaps are not exactly what I would recommend for most backyard mechanics.&nbsp This really requires an acetylene torch to heat quickly; I dunno about you, but I don't have a acetylene torch outfit sitting in my garage...
-Ted
Old Jul 10, 2002 | 04:23 PM
hIGGI's Avatar
i am not worried about using torch, if it will cure my problem, i will find it and use it..
Old Jul 10, 2002 | 05:10 PM
what kinda kit did you buy ?
Old Jul 10, 2002 | 05:18 PM
rx7_ragtop's Avatar
From: Ft. Worth, Texas, USA, Earth, Solar System...
I think that is the way they come there... but when you can get a light flywheel for about $150 US SHIPPED, that's a good deal even having to swap the ring gear.
Brad
Old Jul 10, 2002 | 05:36 PM
jarrod's Avatar
take it to a machine shop and have them install it
also I would consider putting new ring gear on....
if you old one is worn at all ...
I carried a similar project to a local machine shop
and they only charged me 20.00....
Old Jul 11, 2002 | 12:32 AM
hIGGI's Avatar
a) no machine shop here (which will have experience with it)
b) shipping/customs were more than flywheel itself.....
Old Jul 11, 2002 | 12:40 AM
AreExSeven's Avatar
Huh?
Just crawl under the car and unbolt the transmission and crank it with a screwdriver every time you want to start it
Old Jul 11, 2002 | 12:54 AM
autocrash's Avatar
Now with more 1st Gen!
lol... thats gonna suck....
Old Jul 11, 2002 | 02:19 AM
TonyTurboII's Avatar
Glock Lover
What will he push on the flywheel? Not the teeth.
Old Jul 11, 2002 | 03:52 AM
Liquid Anarchy's Avatar
We come with the Hardcore
It's easy to get the teeth off of the stock flywheel, just throw a puller on it, and yank the teeth off ( I did that by accident when I was trying to remove my flywheel for my rebuild ).
now... installing it would be an issure for you... Maybe go buy some leather gloves, throw the ring in an oven, get something to put on the floor. Bake the ring, once it's nice and toasty, take it out, throw it on the flywheel, and drag that outside to cool down??
I don't need to worry about it... I happen to have an acetylene torch outfit sitting in my garage...
~Colby
( Yes, I really do )
Old Jul 11, 2002 | 12:55 PM
hIGGI's Avatar
i will fit it...just installed short shift kit, goes hard now, but works ;o)
Old Jul 11, 2002 | 06:04 PM
Barwick's Avatar
SCCA Rookie
oh.. come on you WIMP!!! just park it on a hill every night, then you don't even need a push to get it started, just roll down the hill and pop it into gear.
Heck, you can get rid of your starter then too.. light weight!!
Old Jul 12, 2002 | 12:37 AM
hIGGI's Avatar
i found out thats the reason why its called super-light flywheel - you are loosing lot of by gettin rid of starter ;p
Old Jul 12, 2002 | 02:06 AM
AreExSeven's Avatar
Huh?
eh?
Old Jul 12, 2002 | 04:56 AM
SonicRaT's Avatar
Super Raterhater
Jesus, all the ricers will be removing their ring gears & starters now and having model-a cranks on the front
Old Jul 12, 2002 | 09:53 AM
Barwick's Avatar
SCCA Rookie
AreExSeven: that was about the funniest thing I've ever seen.. where'd you get that?
Old Jul 12, 2002 | 01:27 PM
AreExSeven's Avatar
Huh?
I just made it to illustrate my point.
I took his flywheel, and a screwdriver I found on sears.com and put em together Im glad you liked it
Old Jul 12, 2002 | 01:44 PM
peejay's Avatar
Old [Sch|F]ool
Put the flywheel in the freezer, the ring gear in the oven, and go at it!
Old Jul 12, 2002 | 02:43 PM
hIGGI's Avatar
i think BBQ event will be better ;o)
Old Jul 14, 2002 | 06:55 PM
hIGGI's Avatar
BBQ party over, results are here :o)
http://rx7cz.net/photos/works09/
(btw...what kind of bolts i should use for a) bolting clutch onto flywheel from one side and b) bolting flywheel to counterweight ?
thanks
LongDuck
Oct 7, 2015 08:12 PM
