How to tell GTUs Rear Diff outside of car?
Old Jul 9, 2002 | 01:35 PM
SoloIIdrift's Avatar
Question How to tell GTUs Rear Diff outside of car?
I was curious, does anyone know how to tell if the entire diff (pumpkin) is a true GTUs diff? As in the ratio of 4.33. I was searching previous posts and saw someone had a technique of marking the drive shaft and then spinning the wheel once around, the driveshaft should rotate 4.33 times around or something.
Would I be able to do this if it's just the bare pumpkin? As in the gears are inside the diff but no 1/2 shafts to or driveshaft to measure how many times they turn.
Anyone?
Old Jul 9, 2002 | 01:38 PM
j9fd3s's Avatar
Community Builder
if its a bare pumpkin then you can count the teeth and do the math: 33 ring gear teeth/ 15 pinion gear teeth =
2.2:1
mike
Old Jul 9, 2002 | 01:39 PM
Silkworm's Avatar
Has been.. hangin' around
Yes, you can do that. Mark your halfshaft output flange on one side, and move it one full rotation. The driveshaft flange will move 3.9 times, 4.1 times or 4.3 times depending on the gear set. Mark the driveshaft flange to make sure you get a good starting point.
PaulC
Old Jul 9, 2002 | 01:51 PM
Very cool! Thanks for the advice.
I don't think the gears are exposed so I'll do the trick you said Paul.
Do you think I'll be able to gauge the difference between 4.1 and 4.3 just by the number of rotations?
Maybe I'll practice on my stock 4.1's and see where it ends up so I can compare.
Old Jul 9, 2002 | 01:53 PM
RarestRX's Avatar
NA Powah, Every Hour!
Yo,
Well, it sounds like it's not in the car...but if it is...
80mph on the speedo should be around 4,000rpm.
KS
1989 GTUs "Wave goodbye to your gas mileage..."
Silkworm's Avatar
That's the tricky part, and why you have to mark very carefully, but yeah, I think you can.
PaulC
Old Jul 9, 2002 | 04:31 PM
NZConvertible's Avatar
I'm a boost creep...
Like Paul said, carefully mark the driveshaft flange. Put you mark at the top and count the number of times it comes past the top as you turn the halfshaft flanges. A 3.9:1 won’t quite make 4 rotations, a 4.1:1 will make 4 rotations then go 36º further, and a 4.3:1 will make 4 rotational then go 108º (more that ¼ turn) further. Should be easy to tell.
BNR34RB26DETT
42
Feb 28, 2018 11:27 AM
Marty RE
Aug 13, 2015 11:19 AM
