Way out there swap!!
I am in need of some info here. Ive looked into a swap that will make you guys cringe lol. I was Thinking of a Ford 3.8L V6 out of the 86-91 Mustang. what i need to know is It plausible and what would be needed to Make 300-400 Hp at the crank with a Turbo set up. i want to Use the Engine and Trans together so no need for adapters to mate the engine to the Fc trans. what wiring do i need to modify. ill be going Carbed so no need for a Ecu. any Input and HELP not bad mouthing would be great. let the iDeas and Info Flow Guys
yeah i dont get it. i didnt think mustang had a 3.8 v6 through the late 80s. thought it was either 4cyl or v8 but i could be wrong.
either way, you could make a lot more power with a 5.0 or 350 for probably similar or less money.
Digital i found 2 Videos on you tube with a TT 3.8l V6 from the Mustang. Steven yeah they did i looked
its Rare tho.http://www.youtube.com/watch?v=AAyyH...eature=related
If you want a V6 mustang motor, get a V6 mustang... I just don't get the V-whatever into Rx7's. Start with a similar sized V6/8 car Like a fox body mustang. No need to waste time and money doing the swap.
Trending Topics
the 86-93 mustang either had the 2.3L 4 or the 5 slow... they didn't have a v6 mustang until the "new" fairmont err mustang came out in 94?
http://en.wikipedia.org/wiki/Ford_Mu...2.80.931993.29
you do know those v6 mustangs all blew up under warranty right?
like sen2 said, totally pointless swap, you might as well find a v6 mustang...
http://en.wikipedia.org/wiki/Ford_Es...gine_(Canadian)
If you insist on using such a poor platform, at least get a leg up on power and get the F150 4.2 shortblock, toss ported 3.8 heads on it, get a huge cam, lightweight flywheel, spend a whole bunch of money getting a T-5 or TKO to fit behind it, and then start breaking N/A diffs and stub axles like they're toothpicks.
been saying the same thing locally.
Why go through the big trouble of swapping a foreign motor in and going for a crappy 200hp v6?
My lm7 with just a cam will put out as much power as the turbo'd v6.
Just because the motor is cheap, doesn't make it a good swap. That's like putting a CA18 into a FC just because you can get the motors
gtcd
Sep 17, 2015 01:15 PM
gabescanlon
Sep 15, 2015 06:57 AM
jakeishness
11
Sep 11, 2015 11:33 AM
