Sponsored by: CARiD
Starting problem very confused
Old Jul 7, 2002 | 01:48 PM
1slick7's Avatar
Question Starting problem very confused
For the past couple weeks when ever i start my car i notice that it is a little rough, and then yesturday i went out, and when i was going to leave the car wouldn't start but it sounded like starter was done because when i turned the key it would make that grinding noise that your engine would make when it was already running and you turned the key again after that it would make a winding down noise so at this point i very confused. I believe its the starter if so how much does that cost generally?
Old Jul 7, 2002 | 03:52 PM
It sounds like your are right the starter went out. You can pick up starters on ebay all day long, or check your local junk yards, I wouldnt think you would pay more than $50 at the most for a good used one. But I'm sure some of the gurus on here can help you find a new one if that is what you are loking for.
alphawolff
Nov 17, 2015 05:57 PM
1993fd3sracer1
29
Oct 13, 2015 01:57 PM
The Shaolin
Sep 14, 2015 07:50 PM
1993fd3sracer1
20
Sep 7, 2015 11:50 AM
