FULL slicks and no oil baffle plate. Bad IDEA?
Old Feb 26, 2011 | 04:57 PM
junito1's Avatar
F**K THE SYSTEM!!
JUst like it says.. I will start using slicks in about 2 months and i do not have a oil baffle plate. The tires are on their way. But I was thinking twice about putting them on before a oil baffle.
Old Feb 26, 2011 | 05:35 PM
jjcobm's Avatar
Are you experienced?
Are you going to be doing wheel stands?
Old Feb 26, 2011 | 08:32 PM
SpeedOfLife's Avatar
rotors excite me
Oil baffle plate becomes useful for hard cornering, too.
Old Feb 26, 2011 | 09:34 PM
Syritis's Avatar
if you can keep your oil at the full level all the time it shouldn't be an issue, I have noticed that when the oil sloshes to the driver side it tends to end up into the catch can, thus having a hard time keeping the oil topped up. I've heard of guys adding a vent to the passenger side and reduces a lot of oil loss. I'll be trying it this year.
so the choice comes down to oil baffle or extra vent?
Old Feb 26, 2011 | 09:57 PM
K-Tune's Avatar
FD Daily
oil can climb up the oil filler neck on hard right turns..
Old Feb 27, 2011 | 02:55 AM
rotors excite me
Part of the point of the baffle plate is to reduce the amount of bubbly oil the pickup tries to draw.
Old Feb 27, 2011 | 09:05 AM
junito1's Avatar
F**K THE SYSTEM!!
THis is for cornering purposes not drag racing.. IM just extra [picky about my motor being reliable... Im think i will spend the money and get the baffle plate.
Old Feb 27, 2011 | 09:22 AM
rotors excite me
buy a stud kit, too. when you add the plate and the extra gasket you can barely grab thread with the stock bolts.
Old Feb 27, 2011 | 10:17 AM
jgrewe's Avatar
GET OFF MY LAWN
Skip the gaskets and just use grey silicone and follow the directions.
Old Feb 27, 2011 | 11:42 AM
Slammedblk7's Avatar
Yes its slow
No baffle here
Old Feb 27, 2011 | 12:00 PM
junito1's Avatar
F**K THE SYSTEM!!
^^ You run slicks? Tire and suspension pecs please.
And how often do you track your car. ANd are 13b-t oil pan/pick up same as 13b-re?
Old Feb 27, 2011 | 05:53 PM
eage8's Avatar
1308ccs of awesome
I autocrossed my car a few time on Hoosiers A6s before I got my new oil pan with a baffle plate (pineapple racing) and it seemed to work find.
I had Hoosier A6s 245/40/17 F - 275/40/17 R
I would just keep your oil level full....
But if you're extra picky... A baffle really isn't very expensive. It's a pain in the butt to install though. There are a lot of bolts
Turblown
Aug 14, 2015 04:48 PM
