Sponsored by: CARiD
How Much do 60 footers help ur E/t?
Old Jul 6, 2002 | 04:41 PM
Boost Junkie's Avatar
Hey guys,
I waz just wondering how much 60 ft times imporoved ur E/t and trap speed?
Cuz a friend of mine ran a 14.4 @ 103 with a 2.5 60 footer...Just curious how much he could improve his E/t and or trap speed....?
Old Jul 7, 2002 | 12:42 AM
peejay's Avatar
Old [Sch|F]ool
Notr so much trap speed but ET, definitely!!!
1/4 mile races are usually won or lost in the first 60 feet, or 330 feet. The launch is EVERYTHING. You get nmore gain by makign the slow parts faster, instead of the fast parts faster.
Old Jul 7, 2002 | 01:22 AM
choritsu-shi's Avatar
I don't think my numbers are right but, I thought there was some kind un-written rule that for every 0.2 second improved on your 60 ft time will result in a 0.1 second improvment on your 1/4 mile time... or was it 0.1 second improved on your 60 ft time will result in a 0.02 second improvment on your 1/4 mile time... Anyone ever hear of something like that???
Sensei
Old Jul 7, 2002 | 01:51 AM
AnthonyNYC's Avatar
Stay tuned...
Sensei
It's acutually for ever 1/10 you save in the first 60ft, you gain 2/10's in the quarter.
From my personal experience, the easiest way to get your car faster in the quarter is by improving your 60ft time.
I was running mid 11's (11.4-11.6) and added some gears, and dropped my 60ft time from a high 1.6 to a mid 1.5 and the car ran 11.1-11.2 very consistently.
Hope that helps.
Anthony
Old Jul 7, 2002 | 03:34 AM
thanx....
Yea i assume if he drops his 60 footer to like 2.2 atleast he could run mid high 13's and a better trap seeing that he waz basicly bogging like crazy off the line...
Old Jul 7, 2002 | 05:06 AM
peejay's Avatar
Old [Sch|F]ool
Jeez, I was running fairly consistent 2.1 60' times with this setup...
3.90 gears
Open diff
185/70-13 economy tires (Goodyears have "Heat-n-Hook" rubber compounds!) at 20psi
12A engine that would bog and fall flat on its face at about 30 feet
If I could have eliminated the bog, my 60's would easily have been in the 1.9-1.8 range. Of coruse the easiest way to do that would be to get lower rear gears so it wouldn't bog out the engine when the clutch grabbed
Old Jul 7, 2002 | 04:31 PM
Originally posted by peejay
Open diff
Open differential...?Sorry ive heard this term being thrown around quite some but what exactly does it mean..and whats the difference between that and uhh i guess closed differential...Sorry i know its dumb too ask...but hey better to ask than to pretend to know right?
Old Jul 9, 2002 | 12:20 AM
peejay's Avatar
Old [Sch|F]ool
Open diff is just a standard diff... if one tire starts spinning, there is no mechanism to prevent it. As opposed to a LSD which has clutch packs or (sometimes) worm gears or (sometimes) a viscous coupling that tried to keep both tires spinning the same speed, or a welded diff/spool which is a non-differential - both tires spin the same speed no matter what.
Open diffs are tricky
Old Jul 9, 2002 | 12:34 AM
Thanx for the info...you rock
sk8world
Rotary Drag Racing
26
Apr 23, 2008 07:16 AM
1987RX7guy
Time Slips and Dyno
28
Aug 31, 2004 04:43 PM
picazo505
Aug 1, 2002 01:39 AM
