Tuning an S-AFC to Torque Curve
Old Jul 5, 2002 | 04:37 AM
Liquid Anarchy's Avatar
We come with the Hardcore
A friend of mine is getting an S-AFC and instead of using an A/F Gague, I suggested just going to the local dyno, and tuning it to his torque curve, as I heard that's the best way. However...
I'm not sure if anyone there knows how to do that.
Can someone explain to me the process? Or point me to a page where I can read about it or something???? Thanks.
~N/A Colby
Old Jul 5, 2002 | 04:58 PM
NZConvertible's Avatar
I'm a boost creep...
I think you've slightly misunderstood what your friend has said. The torque an engine produces is the result of everything done to an engine, including A/F ratios. When you tune on a dyno, you adjust the A/F ratios to maximise power and torque while still providing an adequate safety margin against detonation. A dyno equipped with a wide-band A/F meter is the best way to do this. Experienced dyno tuners know what A/F numbers to aim for for best results.
Logan Reinisch
44
Sep 17, 2018 12:20 PM
Andrew7dg
Aug 6, 2017 01:41 PM
demetlaw
Oct 2, 2015 06:22 PM
93FD510
Oct 1, 2015 02:00 PM
