Cats ??
Old Jul 4, 2002 | 06:21 PM
86rx-7's Avatar
Question Cats ??
Hi,
I want know what are the advantages of pulling out cats. Will there be a noticeable increase in hp ? Will it sounds to strong ? Any others informations will be interesting.
Thanks
Alex
Old Jul 4, 2002 | 06:41 PM
jarrod's Avatar
for one you will lose your working 5th and 6th ports
unless you hook them up to smog pump like later models
Old Jul 4, 2002 | 06:53 PM
NixxoN's Avatar
What are the effects of losing your 5th and 6th ports?
Old Jul 4, 2002 | 07:27 PM
jarrod's Avatar
on 86-(???) N/A models use back pressure
from cats to operate 5&6th ports...
around 4,ooo rpms there is enough back pressure
to open 2 more ports allowing more air flow
into engine.
but there are ways to make them function via
other means..like on later model N/A that use
smog pump pressure to operate ports
as far as effects go ...with non working ports
is you engine will not have the right amount of air
flow at higher rpms..
but if you wire them open you will loose bottom end...
now if you have ported engine thats another can of worms.....
Old Jul 5, 2002 | 04:21 PM
86rx-7's Avatar
thank you
Is this change hard to do ?
Old Jul 5, 2002 | 04:43 PM
jarrod's Avatar
it wasn't hard at all
just do a search on 5th and 6th ports there is a very
good diagram and pics on this...
sorry wish I could remember where it was
ls1swap
Jun 3, 2024 03:25 PM
Andrew7dg
Aug 6, 2017 01:41 PM
