front caliper is frozen
Old Jan 13, 2011 | 12:33 PM
revhardallday's Avatar
Bang Bang!
hey guys,
well i was checking my 93 fd today and to see if there were and thing that needed to be done before state inspection, everything seemed okay until i tryed to rotata my front left wheel by hand it it was stuck, i know that the caliper is frozen/stuck as one might call it, well i was wondering if theres a way to "unstuck" it, im thinking about removing the calipre and pushing the pistons back to see if it will get stuck again. any ideas?
Old Jan 13, 2011 | 12:44 PM
DaleClark's Avatar
RX-7 Bad Ass
That's just what I would do. If it's messed up, I'd just get a good used caliper and replace it.
Dale
Old Jan 13, 2011 | 01:13 PM
ptrhahn's Avatar
You sure the pads aren't just rusted to the rotor? Has it been driven in a while?
Old Jan 13, 2011 | 01:49 PM
Bang Bang!
i put new pads and rotors on the car last month the pistons went back in fine, its all new brakes and the car gets driven 2-3 times a week.
Old Jan 13, 2011 | 02:00 PM
yourmom23's Avatar
I had this exact problem i would be driving down the rode and they would get stuck after braking and i would feel them holding my damn car back. I rebuilt the calipers and it stopped rebuild kit is cheap and easy plus it gives you an excuse to paint them.
Old Jan 13, 2011 | 02:49 PM
Bang Bang!
that sounds like something i would try to do. did u do both or just the stuck one. where did you buy the rebuild kit?
Old Jan 13, 2011 | 02:59 PM
adam c's Avatar
Cheap Bastard
Driving it will likely break it loose.
Old Jan 13, 2011 | 03:33 PM
Bang Bang!
yea but its holding the car back quite a bit i dont want to overheat the rotor and pads, they are new, also the car wont roll down a small hill in neutral its holding it like im aon the brake pedal a little bit.
Old Jan 13, 2011 | 03:36 PM
Mahjik's Avatar
Mr. Links
Did you check your brake pedal adjustment to make sure it's not pre-loading the MC? Just a thought as I've seen people (not necessarily on here) adjust their pedal with worn brake pads. When new brake pads are installed, since they are full thickness they end up dragging on the rotors from the adjusted brake pedal that was done on worn pads.
Old Jan 13, 2011 | 04:02 PM
yourmom23's Avatar
I did all the brakes the kits are on mazda trix. I didnt have new pads though so it kinda sounds like the adjustment is wrong like Mahjik said.
Old Jan 13, 2011 | 04:06 PM
ORANGESP's Avatar
I had just the smallest amount of rust on the piston lead to jammed up brakes!!
emery cloth did mine wonders, or even 1500 grit wet sand paper... clean everything!!!!!
then clean again...
Old Jan 13, 2011 | 04:18 PM
Bang Bang!
the pedal is ok i never toche it but its only doin it to the right front wheel.
Old Jan 13, 2011 | 04:19 PM
Bang Bang!
then clean again...
looks like ill be doing what just did if it does not work for me then i will get the rebuild kit, like yourmom23 did
Old Jan 13, 2011 | 04:21 PM
Force13B's Avatar
No more G6
Did you open the bleeder to see if it still had pressure?
Old Jan 13, 2011 | 04:23 PM
Force13B's Avatar
No more G6
http://www.mazdatrix.com/getprice.as...m=49-2400-FB05
Old Jan 13, 2011 | 07:17 PM
yourmom23's Avatar
have fun bleeding the brakes its a royal pain in the *** to get them good, better just buy a speed bleeder.
Old Jan 14, 2011 | 10:32 AM
Bang Bang!
yes i checked after you asked and it does have good pressure.
Frisky Arab
13
Aug 18, 2015 05:30 PM
Marty RE
Aug 13, 2015 11:19 AM
